You’ve signed the CLA, vinothkannans. Thank you! This pull request is ready for review.
Teeny-weeny typo
# ignore auto-generated plugin js assets
Using equality (==
) is slightly easier to read than inequality (!=
next if args[:include_disabled] == false && !plugin.enabled?
I tend to prefer select
over find_all
because it’s shorter and I don’t confuse it with all?
plugins.select do |plugin|
Is it possible to keep a test to ensure safe mode is still loading the proper javascript assets?
I spent many hours to keep existing or create new spec tests for this PR. But it looks it’s not possible since all the dynamic file creations are happening only on initial app booting time.
LGTM
