DEV: Delete old test workflow
diff --git a/.github/workflows/run_tests.yml b/.github/workflows/run_tests.yml
deleted file mode 100644
index fb2afda..0000000
--- a/.github/workflows/run_tests.yml
+++ /dev/null
@@ -1,162 +0,0 @@
-name: Plugin Tests
-on: [push, pull_request]
-jobs:
- build:
- name: "${{ matrix.target }}-${{ matrix.build_types }}"
- runs-on: ${{ matrix.os }}
- timeout-minutes: 60
- env:
- DISCOURSE_HOSTNAME: www.example.com
- RUBY_GLOBAL_METHOD_CACHE_SIZE: 131072
- BUILD_TYPE: ${{ matrix.build_types }}
- TARGET: ${{ matrix.target }}
- RAILS_ENV: test
- PGHOST: localhost
- PGUSER: discourse
- PGPASSWORD: discourse
- strategy:
- fail-fast: false
- matrix:
- build_types: ["BACKEND", "FRONTEND"]
- target: ["PLUGINS", "CORE"]
- os: [ubuntu-latest]
- ruby: ["2.6"]
- postgres: ["12"]
- redis: ["4.x"]
- services:
- postgres:
- image: postgres:${{ matrix.postgres }}
- ports:
- - 5432:5432
- env:
- POSTGRES_USER: discourse
- POSTGRES_PASSWORD: discourse
- options: >-
- --mount type=tmpfs,destination=/var/lib/postgresql/data
- --health-cmd pg_isready
- --health-interval 10s
- --health-timeout 5s
- --health-retries 5
- steps:
- - uses: actions/checkout@master
- with:
- repository: discourse/discourse
- fetch-depth: 1
- - name: Install plugin
- with:
- path: plugins/${{ github.event.repository.name }}
- fetch-depth: 1
- - name: Check spec existence
- id: check_spec
- uses: andstor/file-existence-action@v1
- with:
- files: "plugins/${{ github.event.repository.name }}/spec"
- - name: Check qunit existence
- id: check_qunit
- with:
- files: "plugins/${{ github.event.repository.name }}/test/javascripts"
- - name: Setup Git
- run: |
- git config --global user.email "ci@ci.invalid"
- git config --global user.name "Discourse CI"
- - name: Setup packages
- run: |
- sudo apt-get update
- sudo apt-get -yqq install postgresql-client libpq-dev gifsicle jpegoptim optipng jhead
- wget -qO- https://raw.githubusercontent.com/discourse/discourse_docker/master/image/base/install-pngquant | sudo sh
- - name: Update imagemagick
- if: env.BUILD_TYPE == 'BACKEND'
- run: |
- wget https://raw.githubusercontent.com/discourse/discourse_docker/master/image/base/install-imagemagick
- chmod +x install-imagemagick
- sudo ./install-imagemagick
- - name: Setup redis
- uses: shogo82148/actions-setup-redis@v1
- with:
- redis-version: ${{ matrix.redis }}
- - name: Setup ruby
- uses: actions/setup-ruby@v1
- with:
- ruby-version: ${{ matrix.ruby }}
- - name: Setup bundler
- run: |
- gem install bundler -v 2.1.4 --no-doc
- bundle config deployment 'true'
- bundle config without 'development'
- - name: Bundler cache
- uses: actions/cache@v1
- id: bundler-cache
- with:
- path: vendor/bundle
- key: ${{ runner.os }}-gem-${{ hashFiles('**/Gemfile.lock') }}
- restore-keys: |
- ${{ runner.os }}-gem-
- - name: Setup gems
- run: bundle install --jobs 4
- - name: Get yarn cache directory
- id: yarn-cache-dir
- run: echo "::set-output name=dir::$(yarn cache dir)"
- - name: Yarn cache
- id: yarn-cache
- with:
- path: ${{ steps.yarn-cache-dir.outputs.dir }}
- key: ${{ runner.os }}-${{ matrix.os }}-yarn-${{ hashFiles('**/yarn.lock') }}
- restore-keys: |
- ${{ runner.os }}-${{ matrix.os }}-yarn-
- - name: Yarn install
- run: yarn install --dev
- - name: Migrate database
- run: |
- bin/rake db:create
- bin/rake db:migrate
- - name: Create parallel databases
- if: env.BUILD_TYPE == 'BACKEND' && env.TARGET == 'CORE'
- run: |
- bin/rake parallel:create
- bin/rake parallel:migrate
- - name: Core RSpec
- run: |
- bin/turbo_rspec
- bin/rake plugin:spec
- - name: Plugin RSpec
- if: env.BUILD_TYPE == 'BACKEND' && env.TARGET == 'PLUGINS' && steps.check_spec.outputs.files_exists == 'true'
- run: bin/rake plugin:spec[${{ github.event.repository.name }}]
- - name: Core QUnit
- if: env.BUILD_TYPE == 'FRONTEND' && env.TARGET == 'CORE'
- run: bundle exec rake qunit:test['1200000']
- timeout-minutes: 30
- - name: Plugin QUnit
- if: env.BUILD_TYPE == 'FRONTEND' && env.TARGET == 'PLUGINS' && steps.check_qunit.outputs.files_exists == 'true'
- run: bundle exec rake plugin:qunit['${{ github.event.repository.name }}','1200000']
GitHub sha: 1ac1f6ee
