DEV: deprecate blank files for static modal pages
diff --git a/app/controllers/static_controller.rb b/app/controllers/static_controller.rb
index 7037e1f..e743676 100644
--- a/app/controllers/static_controller.rb
+++ b/app/controllers/static_controller.rb
@@ -9,6 +9,7 @@ class StaticController < ApplicationController
   skip_before_action :handle_theme, only: [:brotli_asset, :cdn_asset, :enter, :favicon, :service_worker_asset]
   PAGES_WITH_EMAIL_PARAM = ['login', 'password_reset', 'signup']
+  MODAL_PAGES = ['password_reset', 'signup']
   def show
     return redirect_to(path '/') if current_user && (params[:id] == 'login' || params[:id] == 'signup')
@@ -69,6 +70,11 @@ class StaticController < ApplicationController
       return
+    if MODAL_PAGES.include?(@page)
+      render html: nil, layout: true
+      return
+    end
     raise Discourse::NotFound
diff --git a/app/views/static/password_reset.html.erb b/app/views/static/password_reset.html.erb
deleted file mode 100644
index 0100cc8..0000000
--- a/app/views/static/password_reset.html.erb
+++ /dev/null
@@ -1 +0,0 @@
-<!-- this file is required to show the password reset modal: /password-reset -->
diff --git a/app/views/static/signup.html.erb b/app/views/static/signup.html.erb
index 1c5ecea..0000000
--- a/app/views/static/signup.html.erb
+++ /dev/null
@@ -1 +0,0 @@
-<!-- this file is required to show the signup modal: /signup -->
diff --git a/spec/requests/static_controller_spec.rb b/spec/requests/static_controller_spec.rb
index feec6a3..f6ec174 100644
--- a/spec/requests/static_controller_spec.rb
+++ b/spec/requests/static_controller_spec.rb
@@ -103,16 +103,6 @@ describe StaticController do
         expect(response.body).to include(I18n.t('js.faq'))
         expect(response.body).to include("<title>FAQ - Discourse</title>")
-      it "should return the right response for /signup" do
-        get "/signup"
-        expect(response.status).to eq(200)
-      end
-      it "should return the right response for /password-reset" do
-        get "/password-reset"
-      end
@@ -149,6 +139,18 @@ describe StaticController do
         get "/static/does-not-exist"
         expect(response.status).to eq(404)
+      context "modal pages" do
+        it "should return the right response for /signup" do
+          get "/signup"
+          expect(response.status).to eq(200)
+        end
+        it "should return the right response for /password-reset" do
+          get "/password-reset"
+        end
+      end
     it 'should redirect to / when logged in and path is /login' do
GitHub sha: ad5f5b93
