DEV: Deprecate unused route instead of removing it. (#14030)
We’ll no longer use this route, so we’ll return a 301 with the new URL just in case someone is still using it.
diff --git a/app/controllers/posts_controller.rb b/app/controllers/posts_controller.rb
index d8357c9..0a39c58 100644
--- a/app/controllers/posts_controller.rb
+++ b/app/controllers/posts_controller.rb
@@ -554,6 +554,13 @@ class PostsController < ApplicationController
     render body: nil
+  def flagged_posts
+    deprecate('posts#flagged_posts is deprecated. Please use /review instead.', since: '2.8.0.beta4', drop_from: '2.9')
+    review_queue_url = path("/review?status=all&type=ReviewableFlaggedPost&username=#{params[:username]}")
+    redirect_to review_queue_url, status: 301
+  end
   def deleted_posts
     params.permit(:offset, :limit)
     guardian.ensure_can_see_deleted_posts!
diff --git a/config/routes.rb b/config/routes.rb
index 727ff79..28cb935 100644
--- a/config/routes.rb
+++ b/config/routes.rb
@@ -564,6 +564,7 @@ Discourse::Application.routes.draw do
     get "posts/:id/reply-ids"     => "posts#reply_ids"
     get "posts/:id/reply-ids/all" => "posts#all_reply_ids"
     get "posts/:username/deleted" => "posts#deleted_posts", constraints: { username: RouteFormat.username }
+    get "posts/:username/flagged" => "posts#flagged_posts", constraints: { username: RouteFormat.username }
     %w{groups g}.each do |root_path|
       resources :groups, id: RouteFormat.username, path: root_path do
GitHub sha: 54ad0ecc72cc1f2afb29468426d7722ec791ed89
This commit appears in #14030 which was approved by eviltrout. It was merged by romanrizzi.
