DEV: Destroy application instance after each test (#14455)
Under Ember CLI, we create a new application instance for each test. We were not correctly destroying it after the test, causing many references to be maintaned (e.g. at the end of a test run, Ember.Namespace.NAMESPACES would have an entry for each application instance).
Calling destroy on the application instance tidies up these references, and is one step towards fixing our test memory leak problem. Unfortunately there still seem to be other references being held to the application, so this commit is not a total fix.
diff --git a/app/assets/javascripts/discourse/tests/setup-tests.js b/app/assets/javascripts/discourse/tests/setup-tests.js
index 8ce4374..7201dd8 100644
--- a/app/assets/javascripts/discourse/tests/setup-tests.js
+++ b/app/assets/javascripts/discourse/tests/setup-tests.js
@@ -31,6 +31,7 @@ import { flushMap } from "discourse/models/store";
 import { registerObjects } from "discourse/pre-initializers/inject-discourse-objects";
 import { setupApplicationTest } from "ember-qunit";
 import sinon from "sinon";
+import { run } from "@ember/runloop";
 const Plugin = $.fn.modal;
 const Modal = Plugin.Constructor;
@@ -63,6 +64,10 @@ let app;
 let started = false;
 function createApplication(config, settings) {
+  if (app) {
+    run(app, "destroy");
   app = Application.create(config);
   setApplication(app);
   setResolver(buildResolver("discourse").create({ namespace: app }));
GitHub sha: 7fa2eb52f7e901416e626af511fb5a93ce30c63b
This commit appears in #14455 which was approved by jjaffeux. It was merged by davidtaylorhq.
