DEV: Disable ACE editor worker blobs
This will allow us to remove blob: URLs from the worker-src CSP directive
diff --git a/app/assets/javascripts/admin/components/ace-editor.js b/app/assets/javascripts/admin/components/ace-editor.js
index 123193c..480a896 100644
--- a/app/assets/javascripts/admin/components/ace-editor.js
+++ b/app/assets/javascripts/admin/components/ace-editor.js
@@ -74,6 +74,8 @@ export default Component.extend({
     loadScript("/javascripts/ace/ace.js").then(() => {
       window.ace.require(["ace/ace"], loadedAce => {
+        loadedAce.config.set("loadWorkerFromBlob", false);
         if (!this.element || this.isDestroying || this.isDestroyed) {
           return;
GitHub sha: d5463d2a
