DEV: Do not attempt to change schema of posts table
Changing this requires rebuilding the badge_posts view, so will need to be done separately
Followup to f7d676dc
diff --git a/db/migrate/20200601130900_correct_schema_discrepancies.rb b/db/migrate/20200601130900_correct_schema_discrepancies.rb
index 0531b78..ad18fed 100644
--- a/db/migrate/20200601130900_correct_schema_discrepancies.rb
+++ b/db/migrate/20200601130900_correct_schema_discrepancies.rb
@@ -101,8 +101,6 @@ class CorrectSchemaDiscrepancies < ActiveRecord::Migration[6.0]
       post_details.key
       post_details.value
       post_search_data.locale
-      posts.action_code
-      posts.edit_reason
       schema_migrations.version
       screened_emails.email
       screened_urls.domain
GitHub sha: 472862e8
