DEV: Do not try to send prometheus metrics in test mode
This should remove the noisy output from STDERR
index 9f81ad6..e00003b 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -39,7 +39,7 @@ after_initialize do
   # creates no new threads, this simply adds the instruments
-  DiscoursePrometheus::Reporter::Web.start($prometheus_client)
+  DiscoursePrometheus::Reporter::Web.start($prometheus_client) unless Rails.env.test?
   # happens once per rack application
   if Discourse.running_in_rack?
@@ -76,7 +76,7 @@ after_initialize do
     metric.scheduled = true
     metric.job_name = stat.name
     metric.duration = stat.duration_ms * 0.001
-    $prometheus_client.send_json metric.to_h
+    $prometheus_client.send_json metric.to_h unless Rails.env.test?
   DiscourseEvent.on(:sidekiq_job_ran) do |worker, msg, queue, duration|
@@ -84,6 +84,6 @@ after_initialize do
     metric.scheduled = false
     metric.duration = duration
     metric.job_name = worker.class.to_s
GitHub sha: 8f21ae38
