DEV: Don't use `js.erb` for constants
DEV: Don’t use js.erb for constants
Adds a new rake task to auto generate a constants.js file with the constants present. This makes migrating to Ember CLI easier, but also slightly speeds up asset compilation by having to do less work.
If the constants change you need to run: rake javascripts:update_constants
diff --git a/app/assets/javascripts/discourse/app/components/concerns/category-search-priorities.js.erb b/app/assets/javascripts/discourse/app/components/concerns/category-search-priorities.js.erb
deleted file mode 100644
index 643b177..0000000
--- a/app/assets/javascripts/discourse/app/components/concerns/category-search-priorities.js.erb
+++ /dev/null
@@ -1 +0,0 @@
-export const searchPriorities = <%= Searchable::PRIORITIES.to_json %>;
diff --git a/app/assets/javascripts/discourse/app/components/edit-category-settings.js b/app/assets/javascripts/discourse/app/components/edit-category-settings.js
index 6ee6d77..f0ab1ce 100644
--- a/app/assets/javascripts/discourse/app/components/edit-category-settings.js
+++ b/app/assets/javascripts/discourse/app/components/edit-category-settings.js
@@ -2,7 +2,7 @@ import discourseComputed from "discourse-common/utils/decorators";
 import { empty, and } from "@ember/object/computed";
 import { setting } from "discourse/lib/computed";
 import { buildCategoryPanel } from "discourse/components/edit-category-panel";
-import { searchPriorities } from "discourse/components/concerns/category-search-priorities";
+import { SearchPriorities } from "discourse/lib/constants";
 import Group from "discourse/models/group";
 const categorySortCriteria = [];
@@ -71,7 +71,7 @@ export default buildCategoryPanel("settings", {
   searchPrioritiesOptions() {
     const options = [];
-    Object.entries(searchPriorities).forEach(entry => {
+    Object.entries(SearchPriorities).forEach(entry => {
       const [name, value] = entry;
       options.push({
diff --git a/app/assets/javascripts/discourse/app/lib/concerns/search-constants.js.erb b/app/assets/javascripts/discourse/app/lib/concerns/search-constants.js.erb
index 4cb005c..0000000
--- a/app/assets/javascripts/discourse/app/lib/concerns/search-constants.js.erb
+++ /dev/null
@@ -1 +0,0 @@
-export const PHRASE_MATCH_REGEXP_PATTERN = '<%= Search::PHRASE_MATCH_REGEXP_PATTERN %>';
diff --git a/app/assets/javascripts/discourse/app/lib/constants.js b/app/assets/javascripts/discourse/app/lib/constants.js
new file mode 100644
index 0000000..8b75257
--- /dev/null
+++ b/app/assets/javascripts/discourse/app/lib/constants.js
@@ -0,0 +1,13 @@
+// DO NOT EDIT THIS FILE!!!
+// Update it by running `rake javascript:update_constants`
+export const SearchPriorities = {
+  ignore: 1,
+  very_low: 2,
+  low: 3,
+  normal: 0,
+  high: 4,
+  very_high: 5
+export const SearchPhraseRegexp = '"([^"]+)"';
diff --git a/app/assets/javascripts/discourse/app/lib/highlight-search.js b/app/assets/javascripts/discourse/app/lib/highlight-search.js
index 0d9318f..e7dfc46 100644
--- a/app/assets/javascripts/discourse/app/lib/highlight-search.js
+++ b/app/assets/javascripts/discourse/app/lib/highlight-search.js
@@ -1,4 +1,4 @@
-import { PHRASE_MATCH_REGEXP_PATTERN } from "discourse/lib/concerns/search-constants";
+import { SearchPhraseRegexp } from "discourse/lib/constants";
 import highlightHTML from "discourse/lib/highlight-html";
 export const CLASS_NAME = "search-highlight";
@@ -7,7 +7,7 @@ export default function(elem, term, opts = {}) {
   if (!_.isEmpty(term)) {
     // special case ignore "l" which is used for magic sorting
     let words = _.reject(
-      term.match(new RegExp(`${PHRASE_MATCH_REGEXP_PATTERN}|[^\\s]+`, "g")),
+      term.match(new RegExp(`${SearchPhraseRegexp}|[^\\s]+`, "g")),
       t => t === "l"
diff --git a/app/assets/javascripts/discourse/app/routes/discovery-categories.js b/app/assets/javascripts/discourse/app/routes/discovery-categories.js
index ba07642..c1f440d 100644
--- a/app/assets/javascripts/discourse/app/routes/discovery-categories.js
+++ b/app/assets/javascripts/discourse/app/routes/discovery-categories.js
@@ -8,7 +8,7 @@ import { defaultHomepage } from "discourse/lib/utilities";
 import TopicList from "discourse/models/topic-list";
 import { ajax } from "discourse/lib/ajax";
 import PreloadStore from "discourse/lib/preload-store";
 import { hash } from "rsvp";
 import Site from "discourse/models/site";
@@ -145,7 +145,7 @@ export function openNewCategoryModal(context) {
     allow_badges: true,
     topic_featured_link_allowed: true,
     custom_fields: {},
-    search_priority: searchPriorities.normal
+    search_priority: SearchPriorities.normal
   showModal("edit-category", { model }).set("selectedTab", "general");
diff --git a/lib/tasks/javascript.rake b/lib/tasks/javascript.rake
index d538183..835c83c 100644
--- a/lib/tasks/javascript.rake
+++ b/lib/tasks/javascript.rake
@@ -12,8 +12,24 @@ def library_src
   "#{Rails.root}/node_modules"
-task 'javascript:update' do
+task 'javascript:update_constants' => :environment do
+  constants_js = <<~JS
+    // DO NOT EDIT THIS FILE!!!
+    // Update it by running `rake javascript:update_constants`
+    export const SearchPriorities = #{Searchable::PRIORITIES.to_json};
+    export const SearchPhraseRegexp = '#{Search::PHRASE_MATCH_REGEXP_PATTERN}';
+  JS
+  output_path = "#{Rails.root}/app/assets/javascripts/discourse/app/lib/constants.js"
+  File.write(output_path, constants_js)
+  puts "contants.js created"
+  %x{yarn run prettier --write #{output_path}}
+  puts "constants.js prettified"
+end
+task 'javascript:update' do
   require 'uglifier'
   yarn = system("yarn install")
GitHub sha: 7f373e8b
I am on the fence here cause this is a lot less likely to change, but maybe we also have an integrity test for this?
I’ve added an integrity test:
The only annoying part was mini racer doesn’t handle JS modules.
We are very close to upgrading to latest v8, maybe latest v8 plus harmony will give us modules
@SamSaffron that would be very useful if it works.
