DEV: Drop obsolete code (#170)
index ab2269d..1af9bec 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -256,16 +256,7 @@ SQL
     mount ::DiscourseSolved::Engine, at: "solution"
-  # TODO Drop after Discourse 2.6.0 release
-  if TopicView.respond_to?(:add_post_custom_fields_allowlister)
-    TopicView.add_post_custom_fields_allowlister do |user|
-      ["is_accepted_answer"]
-    end
-  else
-    TopicView.add_post_custom_fields_whitelister do |user|
-    end
-  end
+  topic_view_post_custom_fields_allowlister { ["is_accepted_answer"] }
   def get_schema_text(post)
     post.excerpt(nil, keep_onebox_body: true).presence || post.excerpt(nil, keep_onebox_body: true, keep_quotes: true)
GitHub sha: 668ea21131f3e2dc2386044ea2659aa0687a3cb2
This commit appears in #170 which was approved by romanrizzi. It was merged by CvX.
