DEV: Drop old IE11 intersection-observer references (#12942)
It’s been awhile since we have supported IE11 so it should be safe to remove IntersectionObserver now.
From a TODO task in this repo:
drop when we eventually drop IE11
Announcement of when we removed IE11 support:
https://meta.discourse.org/t/137984/40?u=blake
diff --git a/app/assets/javascripts/vendor.js b/app/assets/javascripts/vendor.js
index d001928..d49ec43 100644
--- a/app/assets/javascripts/vendor.js
+++ b/app/assets/javascripts/vendor.js
@@ -23,5 +23,4 @@
 //= require jquery.autoellipsis-1.0.10
 //= require virtual-dom
 //= require virtual-dom-amd
-//= require intersection-observer
 //= require discourse-shims
diff --git a/lib/tasks/javascript.rake b/lib/tasks/javascript.rake
index 2ab50b5..a40bd98 100644
--- a/lib/tasks/javascript.rake
+++ b/lib/tasks/javascript.rake
@@ -141,9 +141,6 @@ def dependencies
       source: 'resumablejs/resumable.js'
-      # TODO: drop when we eventually drop IE11, this will land in iOS in version 13
-      source: 'intersection-observer/intersection-observer.js'
       source: 'workbox-sw/build/.',
       destination: 'workbox',
       public: true,
diff --git a/package.json b/package.json
index 4cdf681..93ab744 100644
--- a/package.json
+++ b/package.json
@@ -19,7 +19,6 @@
     "eslint-config-discourse": "^1.1.8",
     "handlebars": "^4.7.0",
     "@highlightjs/cdn-assets": "^10.6.0",
-    "intersection-observer": "^0.5.1",
     "jquery": "3.5.1",
     "jquery-color": "3.0.0-alpha.1",
     "jquery-tags-input": "1.3.5",
diff --git a/vendor/assets/javascripts/intersection-observer.js b/vendor/assets/javascripts/intersection-observer.js
deleted file mode 100644
index 7a07965..0000000
--- a/vendor/assets/javascripts/intersection-observer.js
+++ /dev/null
@@ -1,726 +0,0 @@
- * Copyright 2016 Google Inc. All Rights Reserved.
- * Licensed under the W3C SOFTWARE AND DOCUMENT NOTICE AND LICENSE.
- *  https://www.w3.org/Consortium/Legal/2015/copyright-software-and-document
-(function(window, document) {
-'use strict';
-// Exits early if all IntersectionObserver and IntersectionObserverEntry
-// features are natively supported.
-if ('IntersectionObserver' in window &&
-    'IntersectionObserverEntry' in window &&
-    'intersectionRatio' in window.IntersectionObserverEntry.prototype) {
-  // Minimal polyfill for Edge 15's lack of `isIntersecting`
-  // See: https://github.com/w3c/IntersectionObserver/issues/211
-  if (!('isIntersecting' in window.IntersectionObserverEntry.prototype)) {
-    Object.defineProperty(window.IntersectionObserverEntry.prototype,
-      'isIntersecting', {
-      get: function () {
-        return this.intersectionRatio > 0;
-  return;
- * An IntersectionObserver registry. This registry exists to hold a strong
- * reference to IntersectionObserver instances currently observing a target
- * element. Without this registry, instances without another reference may be
- * garbage collected.
-var registry = [];
- * Creates the global IntersectionObserverEntry constructor.
- * https://w3c.github.io/IntersectionObserver/#intersection-observer-entry
- * @param {Object} entry A dictionary of instance properties.
- * @constructor
-function IntersectionObserverEntry(entry) {
-  this.time = entry.time;
-  this.target = entry.target;
-  this.rootBounds = entry.rootBounds;
-  this.boundingClientRect = entry.boundingClientRect;
-  this.intersectionRect = entry.intersectionRect || getEmptyRect();
-  this.isIntersecting = !!entry.intersectionRect;
-  // Calculates the intersection ratio.
-  var targetRect = this.boundingClientRect;
-  var targetArea = targetRect.width * targetRect.height;
-  var intersectionRect = this.intersectionRect;
-  var intersectionArea = intersectionRect.width * intersectionRect.height;
-  // Sets intersection ratio.
-  if (targetArea) {
-    // Round the intersection ratio to avoid floating point math issues:
-    // https://github.com/w3c/IntersectionObserver/issues/324
-    this.intersectionRatio = Number((intersectionArea / targetArea).toFixed(4));
-  } else {
-    // If area is zero and is intersecting, sets to 1, otherwise to 0
-    this.intersectionRatio = this.isIntersecting ? 1 : 0;
- * Creates the global IntersectionObserver constructor.
- * https://w3c.github.io/IntersectionObserver/#intersection-observer-interface
- * @param {Function} callback The function to be invoked after intersection
- *     changes have queued. The function is not invoked if the queue has
- *     been emptied by calling the `takeRecords` method.
- * @param {Object=} opt_options Optional configuration options.
- * @constructor
-function IntersectionObserver(callback, opt_options) {
-  var options = opt_options || {};
-  if (typeof callback != 'function') {
-    throw new Error('callback must be a function');
-  if (options.root && options.root.nodeType != 1) {
-    throw new Error('root must be an Element');
-  // Binds and throttles `this._checkForIntersections`.
-  this._checkForIntersections = throttle(
-      this._checkForIntersections.bind(this), this.THROTTLE_TIMEOUT);
-  // Private properties.
-  this._callback = callback;
-  this._observationTargets = [];
-  this._queuedEntries = [];
-  this._rootMarginValues = this._parseRootMargin(options.rootMargin);
-  // Public properties.
-  this.thresholds = this._initThresholds(options.threshold);
-  this.root = options.root || null;
-  this.rootMargin = this._rootMarginValues.map(function(margin) {
-    return margin.value + margin.unit;
-  }).join(' ');
- * The minimum interval within which the document will be checked for
- * intersection changes.
-IntersectionObserver.prototype.THROTTLE_TIMEOUT = 100;
- * The frequency in which the polyfill polls for intersection changes.
- * this can be updated on a per instance basis and must be set prior to
- * calling `observe` on the first target.
-IntersectionObserver.prototype.POLL_INTERVAL = null;
- * Use a mutation observer on the root element
- * to detect intersection changes.
-IntersectionObserver.prototype.USE_MUTATION_OBSERVER = true;
- * Starts observing a target element for intersection changes based on
- * the thresholds values.
- * @param {Element} target The DOM element to observe.
-IntersectionObserver.prototype.observe = function(target) {
-  var isTargetAlreadyObserved = this._observationTargets.some(function(item) {
-    return item.element == target;
-  if (isTargetAlreadyObserved) {
-    return;
-  if (!(target && target.nodeType == 1)) {
-    throw new Error('target must be an Element');
-  this._registerInstance();
-  this._observationTargets.push({element: target, entry: null});
-  this._monitorIntersections();
-  this._checkForIntersections();
- * Stops observing a target element for intersection changes.
-IntersectionObserver.prototype.unobserve = function(target) {
-      this._observationTargets.filter(function(item) {
-    return item.element != target;
-  if (!this._observationTargets.length) {
-    this._unmonitorIntersections();
-    this._unregisterInstance();
- * Stops observing all target elements for intersection changes.
-IntersectionObserver.prototype.disconnect = function() {
- * Returns any queue entries that have not yet been reported to the
- * callback and clears the queue. This can be used in conjunction with the
- * callback to obtain the absolute most up-to-date intersection information.
- * @return {Array} The currently queued entries.
-IntersectionObserver.prototype.takeRecords = function() {
-  var records = this._queuedEntries.slice();
-  return records;
- * Accepts the threshold value from the user configuration object and
- * returns a sorted array of unique threshold values. If a value is not
- * between 0 and 1 and error is thrown.
- * @private
GitHub sha: 1b02dce5
This commit appears in #12942 which was approved by CvX. It was merged by blake.
