DEV: enables and fixes multisite-spec (#9557)
diff --git a/spec/integration/multisite_spec.rb b/spec/integration/multisite_spec.rb
index 4646cab..4aa8af5 100644
--- a/spec/integration/multisite_spec.rb
+++ b/spec/integration/multisite_spec.rb
@@ -1,69 +1,65 @@
 # frozen_string_literal: true
-# require 'rails_helper'
-# describe 'multisite' do
-#   class DBNameMiddleware
-#     def initialize(app, config = {})
-#       @app = app
-#     end
-#     def call(env)
-#       # note current_db is already being ruined on boot cause its not multisite
-#       [200, {}, [RailsMultisite::ConnectionManagement.current_hostname]]
-#     end
-#   end
-#   let :session do
-#     RailsMultisite::ConnectionManagement.config_filename = "spec/fixtures/multisite/two_dbs.yml"
-#     RailsMultisite::ConnectionManagement.load_settings!
-#     stack = ActionDispatch::MiddlewareStack.new
-#     stack.use RailsMultisite::ConnectionManagement, RailsMultisite::DiscoursePatches.config
-#     stack.use DBNameMiddleware
-#     routes = ActionDispatch::Routing::RouteSet.new
-#     stack.build(routes)
-#   end
-#   it "should always allow /srv/status through" do
-#     headers = {
-#       "HTTP_HOST" => "unknown.com",
-#       "REQUEST_METHOD" => "GET",
-#       "PATH_INFO" => "/srv/status",
-#       "rack.input" => StringIO.new
-#     code, _, body = session.call(headers)
-#     expect(code).to eq(200)
-#     expect(body.join).to eq("test.localhost")
-#   end
-#   it "should 404 on unknown routes" do
-#     headers = {
-#       "PATH_INFO" => "/topics",
-#     code, _ = session.call(headers)
-#     expect(code).to eq(404)
-#   end
-#   it "should hit correct site elsewise" do
-#     headers = {
-#       "HTTP_HOST" => "test2.localhost",
-#     expect(body.join).to eq("test2.localhost")
-#   end
-# end
+require 'rails_helper'
+describe 'multisite', type: :multisite do
+  class DBNameMiddleware
+    def initialize(app, config = {})
+      @app = app
+    end
+    def call(env)
+      # note current_db is already being ruined on boot cause its not multisite
+      [200, {}, [RailsMultisite::ConnectionManagement.current_hostname]]
+    end
+  end
+  let :session do
+    stack = ActionDispatch::MiddlewareStack.new
+    stack.use RailsMultisite::Middleware, RailsMultisite::DiscoursePatches.config
+    stack.use DBNameMiddleware
+    routes = ActionDispatch::Routing::RouteSet.new
+    stack.build(routes)
+  end
+  it "should always allow /srv/status through" do
+    headers = {
+      "HTTP_HOST" => "unknown.com",
+      "REQUEST_METHOD" => "GET",
+      "PATH_INFO" => "/srv/status",
+      "rack.input" => StringIO.new
+    code, _, body = session.call(headers)
+    expect(code).to eq(200)
+    expect(body.join).to eq("test.localhost")
+  end
+  it "should 404 on unknown routes" do
+    headers = {
+      "PATH_INFO" => "/topics",
+    code, _ = session.call(headers)
+    expect(code).to eq(404)
+  end
+  it "should hit correct site elsewise" do
+    headers = {
+      "HTTP_HOST" => "test2.localhost",
+    expect(body.join).to eq("test2.localhost")
+  end
+end
GitHub sha: 01f2819d
This commit appears in #9557 which was approved by eviltrout. It was merged by jjaffeux.
