DEV: ensures stylesheet watcher isn't crashing with gems plugins (#12733)
DEV: ensures stylesheet watcher isn’t crashing with gems plugins (#12733)
  • DEV: ensures stylesheet watcher isn’t crashing with gems plugins
This bug has been exhibited since discourse_dev is now including an auth plugin which was loaded as a relative path instead of an absolute path, eg:
Users/bob/.gem/ruby/2.6.6/gems/discourse_dev-0.1.0/auth/plugin.rb
Instead of
/Users/bob/.gem/ruby/2.6.6/gems/discourse_dev-0.1.0/auth/plugin.rb
diff --git a/lib/stylesheet/watcher.rb b/lib/stylesheet/watcher.rb
index f814d1b..a8bbda5 100644
--- a/lib/stylesheet/watcher.rb
+++ b/lib/stylesheet/watcher.rb
@@ -20,8 +20,14 @@ module Stylesheet
       return @default_paths if @default_paths
       @default_paths = ["app/assets/stylesheets"]
-      Discourse.plugins.each do |p|
-        @default_paths << File.dirname(p.path).sub(Rails.root.to_s, '').sub(/^\//, '')
+      Discourse.plugins.each do |plugin|
+        if plugin.path.to_s.include?(Rails.root.to_s)
+          @default_paths << File.dirname(plugin.path).sub(Rails.root.to_s, '').sub(/^\//, '')
+        else
+          # if plugin doesn’t seem to be in our app, consider it as outside of the app
+          # and ignore it
+          warn("[stylesheet watcher] Ignoring outside of rails root plugin: #{plugin.path.to_s}")
+        end
       @default_paths
GitHub sha: 3157d5ee
This commit appears in #12733 which was approved by davidtaylorhq. It was merged by jjaffeux.
