DEV: Establish AR default connection before running tests.
diff --git a/spec/connection_management_spec.rb b/spec/connection_management_spec.rb
index 60e0249..02c38e2 100644
--- a/spec/connection_management_spec.rb
+++ b/spec/connection_management_spec.rb
@@ -12,8 +12,13 @@ describe RailsMultisite::ConnectionManagement do
     File.expand_path("fixtures/#{name}", File.dirname(__FILE__))
+  before do
+    ActiveRecord::Base.establish_connection
+  end
   after do
     conn.clear_settings!
+    ActiveRecord::Base.remove_connection
   def with_connection(db)
@@ -27,14 +32,6 @@ describe RailsMultisite::ConnectionManagement do
   context 'default' do
-    before do
-      ActiveRecord::Base.establish_connection
-    end
-    after do
-      ActiveRecord::Base.remove_connection
-    end
     it 'has correct all_dbs' do
       expect(conn.all_dbs).to eq(['default'])
@@ -60,28 +57,16 @@ describe RailsMultisite::ConnectionManagement do
   it "inherits prepared_statements" do
     ActiveRecord::Base.configurations[Rails.env]["prepared_statements"] = false
     conn.config_filename = fixture_path("two_dbs.yml")
     expect(conn.connection_spec(db: "second").config[:prepared_statements]).to be(false)
     ActiveRecord::Base.configurations[Rails.env]["prepared_statements"] = nil
-  ensure
   context 'two dbs' do
     before do
-      conn.establish_connection(
-        db: RailsMultisite::ConnectionManagement::DEFAULT,
-        raise_on_missing: true
-    end
-    after do
-      ActiveRecord::Base.connection_handler.clear_all_connections!
     it 'accepts a symbol for the db name' do
GitHub sha: f31f25a8
