DEV: fail fast tests and create FILTER with tests preceeding failure (PR #10373)
GitHub
This is cool and I’d like to try it.
This is not finished though and still buggy, you can either use it from here or wait that I improve it :stuck_out_tongue:
I tried using testId but found the seed would randomize their order. Then I realized, why can’t we use the seed? It seems to work, so I made this patch:
https://github.com/discourse/discourse/commit/18e33395805fe361d7ec5e5cb645699c80734521
