DEV: Fix a flaky test (#13580)
Updated the context name, and fixed a typo that was the source of flakiness.
The error was:
  1) TopicView with a few sample posts #first_post_bookmark_reminder_at gets the first post bookmark reminder at for the user
     Failure/Error: expect(second[:reminder_at]).to eq_time(bookmark1.reminder_at)
       2021-07-01 06:49:40 UTC is not within 1 millisecond of 2021-07-01 06:49:39 UTC
     # ./spec/components/topic_view_spec.rb:426:in `block (4 levels) in <main>'
     # ./spec/rails_helper.rb:279:in `block (2 levels) in <top (required)>'
     # ./bundle/ruby/2.7.0/gems/webmock-3.13.0/lib/webmock/rspec.rb:37:in `block (2 levels) in <top (required)>'
diff --git a/spec/components/topic_view_spec.rb b/spec/components/topic_view_spec.rb
index 0a6e07b..ceef467 100644
--- a/spec/components/topic_view_spec.rb
+++ b/spec/components/topic_view_spec.rb
@@ -4,7 +4,6 @@ require 'rails_helper'
 require 'topic_view'
 describe TopicView do
   fab!(:user) { Fabricate(:user) }
   fab!(:moderator) { Fabricate(:moderator) }
   fab!(:admin) { Fabricate(:admin) }
@@ -219,7 +218,6 @@ describe TopicView do
       PostActionCreator.like(moderator, p2)
       best = TopicView.new(topic.id, nil, best: 99, only_moderator_liked: true)
       expect(best.posts.count).to eq(1)
     it "raises NotLoggedIn if the user isn't logged in and is trying to view a private message" do
@@ -410,7 +408,7 @@ describe TopicView do
-    context "#first_post_bookmark_reminder_at" do
+    context "#bookmarked_posts" do
       let!(:user) { Fabricate(:user) }
       let!(:bookmark1) { Fabricate(:bookmark_next_business_day_reminder, post: topic.first_post, user: user) }
       let!(:bookmark2) { Fabricate(:bookmark_next_business_day_reminder, post: topic.posts[1], user: user) }
@@ -418,12 +416,11 @@ describe TopicView do
       it "gets the first post bookmark reminder at for the user" do
         topic_view = TopicView.new(topic.id, user)
-        bookmarked_posts = topic_view.bookmarked_posts
-        first, second = bookmarked_posts
+        first, second = topic_view.bookmarked_posts
         expect(first[:post_id]).to eq(bookmark1.post_id)
         expect(first[:reminder_at]).to eq_time(bookmark1.reminder_at)
         expect(second[:post_id]).to eq(bookmark2.post_id)
-        expect(second[:reminder_at]).to eq_time(bookmark1.reminder_at)
+        expect(second[:reminder_at]).to eq_time(bookmark2.reminder_at)
       context "when the topic is deleted" do
@@ -432,12 +429,11 @@ describe TopicView do
           PostDestroyer.new(Fabricate(:admin), topic.first_post).destroy
           topic.reload
@@ -467,7 +463,6 @@ describe TopicView do
         expect(recent_posts.first.created_at).to be > recent_posts.last.created_at
   context 'whispers' do
@@ -591,7 +586,6 @@ describe TopicView do
     describe "filter_posts_near" do
       def topic_view_near(post, show_deleted = false)
         TopicView.new(topic.id, evil_trout, post_number: post.post_number, show_deleted: show_deleted)
GitHub sha: 79e850ba19d7c4cdcbf9f81d96130f88679ea2dc
This commit appears in #13580 which was approved by eviltrout. It was merged by CvX.
