DEV: fix and skip upload_controller test
This test of prevent_anons_from_downloading_files was testing an image instead of an attachment and it was testing the wrong upload URL. I fixed the test, but with config.public_file_server.enabled = true on the test environment, this will always fail, as preventing anonymous file downloads depends on nginx. So, I marked the test as skipped, for now.
diff --git a/spec/requests/uploads_controller_spec.rb b/spec/requests/uploads_controller_spec.rb
index 0e2ff0f..9106ea1 100644
--- a/spec/requests/uploads_controller_spec.rb
+++ b/spec/requests/uploads_controller_spec.rb
@@ -198,8 +198,8 @@ describe UploadsController do
     let(:sha) { Digest::SHA1.hexdigest("discourse") }
     let(:user) { Fabricate(:user) }
-    def upload_file(file)
-      fake_logo = Rack::Test::UploadedFile.new(file_from_fixtures(file))
+    def upload_file(file, folder = "images")
+      fake_logo = Rack::Test::UploadedFile.new(file_from_fixtures(file, folder))
       SiteSetting.authorized_extensions = "*"
       sign_in(user)
@@ -261,11 +261,12 @@ describe UploadsController do
     context "prevent anons from downloading files" do
       it "returns 404 when an anonymous user tries to download a file" do
-        upload = upload_file("logo.png")
+        skip("this only works when nginx/apache is asset server") if Discourse::Application.config.public_file_server.enabled
+        upload = upload_file("small.pdf", "pdf")
         delete "/session/#{user.username}.json" # upload a file, then sign out
         SiteSetting.prevent_anons_from_downloading_files = true
-        get "/uploads/#{site}/#{upload.sha1}.#{upload.extension}"
+        get upload.url
         expect(response.status).to eq(404)
GitHub sha: a19d8936
