DEV: Fix another flaky spec (PR #13322)
The error was:
  1) ExtraLocalesController.client_overrides_exist? returns true if there are client-side translation overrides
     Failure/Error: expect(ExtraLocalesController.client_overrides_exist?).to eq(false)
       expected: false
            got: true
       (compared using ==)
       Diff:
       @@ -1 +1 @@
       -false
       +true
     # ./spec/requests/extra_locales_controller_spec.rb:162:in `block (3 levels) in <main>'
     # ./spec/rails_helper.rb:279:in `block (2 levels) in <top (required)>'
     # .gem/ruby/2.7.3/gems/webmock-3.13.0/lib/webmock/rspec.rb:37:in `block (2 levels) in <top (required)>'
Minimal repro:
bin/rspec './spec/models/trust_level_and_staff_setting_spec.rb[1:1:1]' './spec/requests/extra_locales_controller_spec.rb[1:3:2]' --tag ~type:multisite --seed 33616
GitHub
