DEV: Fix broken `Upload#base62_sha1`.
DEV: Fix broken Upload#base62_sha1.
diff --git a/app/models/upload.rb b/app/models/upload.rb
index bfb3fd2..5244d1e 100644
--- a/app/models/upload.rb
+++ b/app/models/upload.rb
@@ -138,7 +138,7 @@ class Upload < ActiveRecord::Base
   def base62_sha1
-    Upload.base62_sha1(upload.sha1)
+    Upload.base62_sha1(self.sha1)
   def local?
diff --git a/spec/models/upload_spec.rb b/spec/models/upload_spec.rb
index 9a62b08..44ff1f1 100644
--- a/spec/models/upload_spec.rb
+++ b/spec/models/upload_spec.rb
@@ -253,6 +253,13 @@ describe Upload do
+  describe '#base62_sha1' do
+    it 'should return the right value' do
+      upload.update!(sha1: "0000c513e1da04f7b4e99230851ea2aafeb8cc4e")
+      expect(upload.base62_sha1).to eq("1Eg9p8rrCURq4T3a6iJUk0ri6")
+    end
+  end
   describe '.sha1_from_short_path' do
     it "should be able to lookup sha1" do
       path = "/uploads/short-url/3UjQ4jHoyeoQndk5y3qHzm3QVTQ.png"
GitHub sha: bb987855
