DEV: Fix build
DEV: Fix build
Follow up to 0653750fbf7d690f96ef064932b3dd44550bcb45.
diff --git a/db/migrate/20200403100259_add_key_hash_to_user_api_key.rb b/db/migrate/20200403100259_add_key_hash_to_user_api_key.rb
index 2e998fc..138cf28 100644
--- a/db/migrate/20200403100259_add_key_hash_to_user_api_key.rb
+++ b/db/migrate/20200403100259_add_key_hash_to_user_api_key.rb
@@ -8,7 +8,7 @@ class AddKeyHashToUserApiKey < ActiveRecord::Migration[6.0]
     loop do
       rows = DB
         .query("SELECT id, key FROM user_api_keys WHERE key_hash IS NULL LIMIT #{batch_size}")
-        .map { |row| { id: row.id, key_hash: Digest::SHA256.hexdigest(key) } }
+        .map { |row| { id: row.id, key_hash: Digest::SHA256.hexdigest(row.key) } }
       break if rows.size == 0
GitHub sha: 2e8f54e9
