DEV: Fix build.
DEV: Fix build.
diff --git a/assets/javascripts/lib/database.js.es6 b/assets/javascripts/lib/database.js.es6
index 52a4636..37bb2e4 100644
--- a/assets/javascripts/lib/database.js.es6
+++ b/assets/javascripts/lib/database.js.es6
@@ -82,7 +82,7 @@ export function saveDbIdentity(identity) {
   if (isSafari) {
     return exportIdentity(identity).then(exported =>
-      window.localStorage.setItem(DB_NAME, exported)
+      window.localStorage.setItem(DB_NAME, exported.private)
diff --git a/assets/stylesheets/common/encrypt.scss b/assets/stylesheets/common/encrypt.scss
index b99f213..9282c35 100644
--- a/assets/stylesheets/common/encrypt.scss
+++ b/assets/stylesheets/common/encrypt.scss
@@ -80,4 +80,4 @@ table.paperkeys {
     color: $danger;
     margin: 0 0 0 0.5em;
\ No newline at end of file
diff --git a/spec/plugin_spec.rb b/spec/plugin_spec.rb
index 6886fa7..df7b532 100644
--- a/spec/plugin_spec.rb
+++ b/spec/plugin_spec.rb
@@ -5,7 +5,7 @@ require 'rails_helper'
 describe ::DiscourseEncrypt do
   it 'registers current user fields' do
-    expect(DiscoursePluginRegistry.serialized_current_user_fields).to include('encrypt_public_key', 'encrypt_private_key', 'encrypt_salt')
+    expect(DiscoursePluginRegistry.serialized_current_user_fields).to include('encrypt_public', 'encrypt_private')
   it 'registers preloaded custom fields' do
diff --git a/spec/requests/encrypt_controller_spec.rb b/spec/requests/encrypt_controller_spec.rb
index d8ff7dc..9c25af9 100644
--- a/spec/requests/encrypt_controller_spec.rb
+++ b/spec/requests/encrypt_controller_spec.rb
@@ -31,9 +31,8 @@ describe ::DiscourseEncrypt::EncryptController do
   context '#update_keys' do
     it 'does not work when not logged in' do
       put '/encrypt/keys', params: {
-        public_key: '-- the public key --',
-        private_key: '-- the private key --',
-        salt: '-- the salt --'
+        public: '-- the public key --',
+        private: '-- the private key --'
       expect(response.status).to eq(403)
@@ -47,18 +46,16 @@ describe ::DiscourseEncrypt::EncryptController do
       sign_in(user)
       Fabricate(:group_user, group: group, user: user)
       expect(response.status).to eq(200)
@@ -67,51 +64,44 @@ describe ::DiscourseEncrypt::EncryptController do
       sign_in(user3)
-      expect(user3.custom_fields['encrypt_public_key']).to eq('-- the public key --')
-      expect(user3.custom_fields['encrypt_private_key']).to eq('-- the private key --')
-      expect(user3.custom_fields['encrypt_salt']).to eq('-- the salt --')
+      expect(user3.custom_fields['encrypt_public']).to eq('-- the public key --')
+      expect(user3.custom_fields['encrypt_private']).to eq('-- the private key --')
     it 'updates user keys' do
       sign_in(user)
-        private_key: '-- the new private key --',
-        salt: '-- the new salt --'
+        private: '-- the new private key --'
       user.reload
-      expect(user.custom_fields['encrypt_public_key']).to eq('-- the public key --')
-      expect(user.custom_fields['encrypt_private_key']).to eq('-- the new private key --')
-      expect(user.custom_fields['encrypt_salt']).to eq('-- the new salt --')
+      expect(user.custom_fields['encrypt_public']).to eq('-- the public key --')
+      expect(user.custom_fields['encrypt_private']).to eq('-- the new private key --')
     it 'does not allow updating if wrong public key' do
-      user.custom_fields['encrypt_public_key'] = '-- the public key --'
-      user.custom_fields['encrypt_private_key'] = '-- the private key --'
-      user.custom_fields['encrypt_salt'] = '-- the salt --'
+      user.custom_fields['encrypt_public'] = '-- the public key --'
+      user.custom_fields['encrypt_private'] = '-- the private key --'
       user.save!
       sign_in(user)
-        public_key: '-- a wrong public key --',
+        public: '-- a wrong public key --',
       expect(response.status).to eq(409)
-      expect(user.custom_fields['encrypt_private_key']).to eq('-- the private key --')
-      expect(user.custom_fields['encrypt_salt']).to eq('-- the salt --')
+      expect(user.custom_fields['encrypt_private']).to eq('-- the private key --')
@@ -122,9 +112,9 @@ describe ::DiscourseEncrypt::EncryptController do
     it 'gets the right user keys' do
       user.save!
-      user2.custom_fields['encrypt_public_key'] = '-- another public key --'
+      user2.custom_fields['encrypt_public'] = '-- another public key --'
       user2.save
       sign_in(user)
@@ -141,9 +131,8 @@ describe ::DiscourseEncrypt::EncryptController do
   context '#reset_user' do
     before do
       user.save_custom_fields
       store.set("key_#{topic.id}_#{user.id}", '-- user key --')
@@ -152,23 +141,21 @@ describe ::DiscourseEncrypt::EncryptController do
     it 'resets everything' do
-      user.grant_admin!
       expect { post '/encrypt/reset', params: { user_id: user.id, everything: true } }
         .to change { TopicAllowedUser.count }.by(-1)
         .and change { PluginStoreRow.count }.by(-1)
-        .and change { UserCustomField.count }.by(-3)
+        .and change { UserCustomField.count }.by(-2)
-    it 'allows only staff members' do
+    it 'resets only keys' do
       expect { post '/encrypt/reset', params: { user_id: user.id } }
         .to change { TopicAllowedUser.count }.by(0)
         .and change { PluginStoreRow.count }.by(0)
-        .and change { UserCustomField.count }.by(0)
-      expect(response.status).to eq(403)
+      expect(response.status).to eq(200)
diff --git a/test/javascripts/lib/protocol_v1-test.js.es6 b/test/javascripts/lib/protocol_v1-test.js.es6
index 0205a3d..64318fe 100644
--- a/test/javascripts/lib/protocol_v1-test.js.es6
+++ b/test/javascripts/lib/protocol_v1-test.js.es6
@@ -24,11 +24,16 @@ test("exportIdentity & importIdentity", async assert => {
   const identity = await generateIdentity();
GitHub sha: 9de1ecbc
