DEV: Fix flaky site.json api test (#14351)
The color_scheme_id needs to be an integer not a string.
This is one of the failing tests that showed this error:
https://github.com/discourse/discourse/runs/3598414971
It showed this error
POSSIBLE ISSUE W/: /user_themes/0/color_scheme_id
And this is part of the site.json response:
"user_themes"=>[{"theme_id"=>149, "name"=>"Cool theme 111", "default"=>false, "color_scheme_id"=>37}]
diff --git a/spec/requests/api/schemas/json/site_response.json b/spec/requests/api/schemas/json/site_response.json
index bda5dad..82ae948 100644
--- a/spec/requests/api/schemas/json/site_response.json
+++ b/spec/requests/api/schemas/json/site_response.json
@@ -382,7 +382,7 @@
             "color_scheme_id": {
               "type": [
-                "string",
+                "integer",
                 "null"
GitHub sha: 91453dd3fc75c34d544e8455be0c805bf487716c
This commit appears in #14351 which was approved by lis2. It was merged by blake.
