DEV: Fix flaky spec (#94)
The issue was that when we were moving the post using posts[1,2] the ordering was not always consistent, so sometimes we moved post number 1 for the topic and sometimes post number 2.
If post number 1 was moved, the PostMover just creates a copy of it in the destination topic, as the OP of the topic cannot be moved.
If post number 2 was moved, then PostMover actually moves it to the destination topic, and thus leaves only one post behind in the original topic, which causes the original topic to be closed and makes the spec fail.
This change ensures that post number 1 is the one we are moving in the test, making sure the order is constant.
diff --git a/spec/voting_spec.rb b/spec/voting_spec.rb
index ecb3da1..6e1f9ae 100644
--- a/spec/voting_spec.rb
+++ b/spec/voting_spec.rb
@@ -4,18 +4,18 @@ require 'rails_helper'
 describe DiscourseVoting do
-  let(:user0) { Fabricate(:user) }
-  let(:user1) { Fabricate(:user) }
-  let(:user2) { Fabricate(:user) }
-  let(:user3) { Fabricate(:user) }
-  let(:user4) { Fabricate(:user) }
-  let(:user5) { Fabricate(:user) }
+  let!(:user0) { Fabricate(:user) }
+  let!(:user1) { Fabricate(:user) }
+  let!(:user2) { Fabricate(:user) }
+  let!(:user3) { Fabricate(:user) }
+  let!(:user4) { Fabricate(:user) }
+  let!(:user5) { Fabricate(:user) }
   let(:category1) { Fabricate(:category) }
   let(:category2) { Fabricate(:category) }
-  let(:topic0) { Fabricate(:topic, category: category1) }
-  let(:topic1) { Fabricate(:topic, category: category2) }
+  let!(:topic0) { Fabricate(:topic, category: category1) }
+  let!(:topic1) { Fabricate(:topic, category: category2) }
   before do
     SiteSetting.voting_enabled = true
@@ -83,25 +83,24 @@ describe DiscourseVoting do
       expect(merged_post.raw).to include(I18n.t('voting.duplicated_votes', count: 2))
-    # Disabling 2021-06-07, super flaky in builds
-    # it 'does not move votes when a single post is moved' do
-    #   topic0.move_posts(Discourse.system_user, topic0.posts[1, 2].map(&:id), destination_topic_id: topic1.id)
-    #   users.each { |user| user.reload }
-    #   expect(users[0].topics_with_vote.pluck(:topic_id)).to contain_exactly(topic0.id)
-    #   expect(users[0].topics_with_archived_vote.pluck(:topic_id)).to be_blank
-    #   expect(users[1].topics_with_vote.pluck(:topic_id)).to contain_exactly(topic1.id)
-    #   expect(users[1].topics_with_archived_vote.pluck(:topic_id)).to be_blank
-    #   expect(users[2].topics_with_vote.pluck(:topic_id)).to contain_exactly(topic0.id, topic1.id)
-    #   expect(users[2].topics_with_archived_vote.pluck(:topic_id)).to be_blank
-    #   expect(users[3].topics_with_vote.pluck(:topic_id)).to be_blank
-    #   expect(users[3].topics_with_archived_vote.pluck(:topic_id)).to be_blank
-    #   expect(users[4].topics_with_vote.pluck(:topic_id)).to be_blank
-    #   expect(users[4].topics_with_archived_vote.pluck(:topic_id)).to contain_exactly(topic0.id)
-    #   expect(topic0.reload.vote_count).to eq(4)
-    #   expect(topic1.reload.vote_count).to eq(3)
-    # end
+    it 'does not move votes when not all posts are moved and the original topic does not get closed' do
+      topic0.move_posts(Discourse.system_user, [topic0.posts.order(:post_number).first.id], destination_topic_id: topic1.id)
+      users.each { |user| user.reload }
+      expect(users[0].topics_with_vote.pluck(:topic_id)).to contain_exactly(topic0.id)
+      expect(users[0].topics_with_archived_vote.pluck(:topic_id)).to be_blank
+      expect(users[1].topics_with_vote.pluck(:topic_id)).to contain_exactly(topic1.id)
+      expect(users[1].topics_with_archived_vote.pluck(:topic_id)).to be_blank
+      expect(users[2].topics_with_vote.pluck(:topic_id)).to contain_exactly(topic0.id, topic1.id)
+      expect(users[2].topics_with_archived_vote.pluck(:topic_id)).to be_blank
+      expect(users[3].topics_with_vote.pluck(:topic_id)).to be_blank
+      expect(users[3].topics_with_archived_vote.pluck(:topic_id)).to be_blank
+      expect(users[4].topics_with_vote.pluck(:topic_id)).to be_blank
+      expect(users[4].topics_with_archived_vote.pluck(:topic_id)).to contain_exactly(topic0.id)
+      expect(topic0.reload.vote_count).to eq(4)
+      expect(topic1.reload.vote_count).to eq(3)
+    end
   context "when a user has an empty string as the votes custom field" do
GitHub sha: 1775d948
This commit appears in #94 which was approved by tgxworld. It was merged by tgxworld.
