DEV: Fix flaky UploadSecurity spec
diff --git a/lib/upload_security.rb b/lib/upload_security.rb
index 0a2acfd..4572473 100644
--- a/lib/upload_security.rb
+++ b/lib/upload_security.rb
@@ -29,6 +29,11 @@ class UploadSecurity
     @@custom_public_types << type if !@@custom_public_types.include?(type)
+  # used in tests
+  def self.reset_custom_public_types
+    @@custom_public_types = []
+  end
   def initialize(upload, opts = {})
     @upload = upload
     @opts = opts
diff --git a/spec/lib/upload_security_spec.rb b/spec/lib/upload_security_spec.rb
index 2ff1220..d154528 100644
--- a/spec/lib/upload_security_spec.rb
+++ b/spec/lib/upload_security_spec.rb
@@ -74,6 +74,7 @@ RSpec.describe UploadSecurity do
           it "returns false if the custom type has been added" do
             UploadSecurity.register_custom_public_type(type)
             expect(subject.should_be_secure?).to eq(false)
+            UploadSecurity.reset_custom_public_types
         describe "for_theme" do
GitHub sha: c664ba8f
@pmusaraj I am not sure we need a public method just to reset these types for the test; I think a UploadSecurity.class_variable_set(:@@custom_public_types, []) would suffice because I can’t think of a situation where we would need to do this in the actual app code.
the downside though is that this makes the tests more fragile long term cause we are reaching to internals to fiddle with stuff. I kind of prefer just leaving this as is.
I guess this is fair enough, just seemed like a smell for me to purely add something for a test but reconsidering I can see that it is a worse smell to mess with internals. Sorry @pmusaraj I guess close your new PR then!
