DEV: Fix heisentest.
Unpause sidekiq before clearning up all threads.
diff --git a/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb b/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb
index 23b3032..826b5f4 100644
--- a/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb
+++ b/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb
@@ -32,8 +32,8 @@ describe ActiveRecord::ConnectionHandling do
   after do
-    (Thread.list - @threads).each(&:kill)
     Sidekiq.unpause!
+    (Thread.list - @threads).each(&:kill)
     postgresql_fallback_handler.setup!
     ActiveRecord::Base.unstub(:postgresql_connection)
GitHub sha: 86a2172b
