DEV: Fix imports in tests (#152)
diff --git a/test/javascripts/acceptance/encrypt-test.js b/test/javascripts/acceptance/encrypt-test.js
index eabe512..25901d7 100644
--- a/test/javascripts/acceptance/encrypt-test.js
+++ b/test/javascripts/acceptance/encrypt-test.js
@@ -1,4 +1,4 @@
-import { visit } from "@ember/test-helpers";
+import { click, fillIn, visit } from "@ember/test-helpers";
 import User from "discourse/models/user";
 import {
   deleteDb,
@@ -22,8 +22,10 @@ import {
   importIdentity,
 } from "discourse/plugins/discourse-encrypt/lib/protocol";
 import { NOTIFICATION_TYPES } from "discourse/tests/fixtures/concerns/notification-types";
-import { default as userFixtures } from "discourse/tests/fixtures/user-fixtures";
-import { parsePostData } from "discourse/tests/helpers/create-pretender";
+import userFixtures from "discourse/tests/fixtures/user-fixtures";
+import pretender, {
+  parsePostData,
+} from "discourse/tests/helpers/create-pretender";
 import {
   acceptance,
   count,
@@ -34,9 +36,10 @@ import {
 } from "discourse/tests/helpers/qunit-helpers";
 import selectKit from "discourse/tests/helpers/select-kit-helper";
 import I18n from "I18n";
-import { test } from "qunit";
+import QUnit, { test } from "qunit";
 import { Promise } from "rsvp";
 import sinon from "sinon";
+import { cloneJSON } from "discourse-common/lib/object";
  * Checks if a string is not contained in a string.
@@ -108,9 +111,8 @@ async function setEncryptionStatus(status) {
   // Setting the appropriate custom fields is not always enough (i.e. if user
   // navigates to preferences).
-  /* global server */
-  server.get("/u/eviltrout.json", () => {
-    const json = userFixtures["/u/eviltrout.json"];
+  pretender.get("/u/eviltrout.json", () => {
+    const json = cloneJSON(userFixtures["/u/eviltrout.json"]);
     json.user.can_edit = true;
     json.user.encrypt_public = exported.public;
     json.user.encrypt_private = exportedPrivate;
@@ -180,17 +182,17 @@ acceptance("Encrypt", function (needs) {
   needs.pretender((server, helper) => {
-    server.get("/encrypt/user", (request) => {
+    pretender.get("/encrypt/user", (request) => {
       const response = {};
       request.queryParams["usernames"].forEach((u) => (response[u] = keys[u]));
       return helper.response(response);
-    server.get("/encrypt/posts", () => {
+    pretender.get("/encrypt/posts", () => {
       return helper.response({ posts: [], topics: [] });
-    server.put("/encrypt/post", () => {
+    pretender.put("/encrypt/post", () => {
       return helper.response({});
@@ -214,8 +216,7 @@ acceptance("Encrypt", function (needs) {
     await setEncryptionStatus(ENCRYPT_ACTIVE);
     globalAssert = assert;
-    server.get("/u/search/users", () => {
+    pretender.get("/u/search/users", () => {
       return [
         200,
         { "Content-Type": "application/json" },
@@ -231,15 +232,15 @@ acceptance("Encrypt", function (needs) {
-    server.post("/posts", (request) => {
+    pretender.post("/posts", (request) => {
       const body = parsePostData(request.requestBody);
-      assert.equal(body.raw, I18n.t("encrypt.encrypted_post"));
-      assert.equal(body.title, I18n.t("encrypt.encrypted_title"));
-      assert.equal(body.archetype, "private_message");
-      assert.equal(body.target_recipients, "eviltrout");
-      assert.equal(body.draft_key, "new_topic");
-      assert.equal(body.is_encrypted, "true");
+      assert.strictEqual(body.raw, I18n.t("encrypt.encrypted_post"));
+      assert.strictEqual(body.title, I18n.t("encrypt.encrypted_title"));
+      assert.strictEqual(body.archetype, "private_message");
+      assert.strictEqual(body.target_recipients, "eviltrout");
+      assert.strictEqual(body.draft_key, "new_topic");
+      assert.strictEqual(body.is_encrypted, "true");
       assert.ok(body.encrypted_title.startsWith("1$"));
       assert.ok(body.encrypted_raw.startsWith("1$"));
       assert.ok(JSON.parse(body.encrypted_keys).eviltrout);
@@ -286,13 +287,13 @@ acceptance("Encrypt", function (needs) {
   test("new draft for public topic is not encrypted", async (assert) => {
-    server.post("/drafts.json", (request) => {
+    pretender.post("/drafts.json", (request) => {
       const data = JSON.parse(parsePostData(request.requestBody).data);
       if (data.title) {
-        assert.equal(data.title, `Some public message ${PLAINTEXT}`);
+        assert.strictEqual(data.title, `Some public message ${PLAINTEXT}`);
       if (data.reply) {
-        assert.equal(data.reply, `Hello, world! ${PLAINTEXT}`.repeat(42));
+        assert.strictEqual(data.reply, `Hello, world! ${PLAINTEXT}`.repeat(42));
       return [200, { "Content-Type": "application/json" }, {}];
@@ -313,8 +314,7 @@ acceptance("Encrypt", function (needs) {
     await setEncryptionStatus(ENCRYPT_DISABLED);
     let ajaxRequested = false;
-    server.put("/encrypt/keys", () => {
+    pretender.put("/encrypt/keys", () => {
       ajaxRequested = true;
       return [200, { "Content-Type": "application/json" }, { success: "OK" }];
@@ -364,7 +364,7 @@ acceptance("Encrypt", function (needs) {
     const encryptedTitle = await encrypt(topicKey, { raw: "Top Secret Title" });
     const encryptedRaw = await encrypt(topicKey, { raw: "Top Secret Post" });
-    server.get("/t/42.json", () => {
+    pretender.get("/t/42.json", () => {
       return [
         200,
@@ -616,7 +616,7 @@ acceptance("Encrypt", function (needs) {
       return [
         200,
@@ -855,9 +855,16 @@ acceptance("Encrypt", function (needs) {
     await visit("/t/a-secret-message/42");
     await visit("/t/a-secret-message/42"); // wait for re-render
-    assert.equal(query(".fancy-title").innerText.trim(), "Top Secret Title");
-    assert.equal(query(".cooked").innerText.trim(), "Top Secret Post");
-    assert.equal(document.title, "Top Secret Title - QUnit Discourse Tests");
+      query(".fancy-title").innerText.trim(),
+      "Top Secret Title"
+    assert.strictEqual(query(".cooked").innerText.trim(), "Top Secret Post");
+      document.title,
+      "Top Secret Title - QUnit Discourse Tests"
   test("encrypt settings visible only if user can encrypt", async (assert) => {
@@ -865,7 +872,7 @@ acceptance("Encrypt", function (needs) {
     await visit("/u/eviltrout/preferences/security");
     assert.ok(
-      find(".encrypt").text().length > 0,
+      query(".encrypt").innerText.trim().length > 0,
       "encrypt settings are visible"
@@ -873,8 +880,9 @@ acceptance("Encrypt", function (needs) {
     await visit("/u/eviltrout/preferences");
     await click(".nav-security a");
-    assert.ok(
-      find(".encrypt").text().length === 0,
+      query(".encrypt").innerText.trim().length,
+      0,
       "encrypt settings are not visible"
@@ -883,7 +891,7 @@ acceptance("Encrypt", function (needs) {
     assert.ok(
@@ -891,11 +899,8 @@ acceptance("Encrypt", function (needs) {
   test("user preferences connector works for other users", async (assert) => {
-    server.get("/u/eviltrout2.json", () => {
GitHub sha: 376213b551a44ede82cc6bbf09bea2d62f5781b1
This commit appears in #152 which was approved by martin. It was merged by CvX.
