DEV: Fix imports in tests (#71)
And replace find with query, equal with strictEqual.
diff --git a/test/javascripts/acceptance/spoiler-button-test.js b/test/javascripts/acceptance/spoiler-button-test.js
new file mode 100644
index 0000000..91f11bc
--- /dev/null
+++ b/test/javascripts/acceptance/spoiler-button-test.js
@@ -0,0 +1,149 @@
+import {
+  acceptance,
+  exists,
+  query,
+} from "discourse/tests/helpers/qunit-helpers";
+import { test } from "qunit";
+import { click, fillIn, visit } from "@ember/test-helpers";
+import I18n from "I18n";
+import selectKit from "discourse/tests/helpers/select-kit-helper";
+import { clearPopupMenuOptionsCallback } from "discourse/controllers/composer";
+acceptance("Spoiler Button", function (needs) {
+  needs.user();
+  needs.settings({ spoiler_enabled: true });
+  needs.hooks.beforeEach(() => {
+    clearPopupMenuOptionsCallback();
+  test("spoiler button", async (assert) => {
+    const popUpMenu = selectKit(".toolbar-popup-menu-options");
+    await visit("/");
+    assert.ok(exists("#create-topic"), "the create button is visible");
+    await click("#create-topic");
+    await popUpMenu.expand();
+    await popUpMenu.selectRowByValue("insertSpoiler");
+    assert.strictEqual(
+      query(".d-editor-input").value,
+      `[spoiler]${I18n.t("composer.spoiler_text")}[/spoiler]`,
+      "it should contain the right output"
+    let textarea = query(".d-editor-input");
+      textarea.selectionStart,
+      9,
+      "it should start highlighting at the right position"
+      textarea.selectionEnd,
+      I18n.t("composer.spoiler_text").length + 9,
+      "it should end highlighting at the right position"
+    await fillIn(".d-editor-input", "This is hidden");
+    textarea.selectionStart = 0;
+    textarea.selectionEnd = textarea.value.length;
+      `[spoiler]This is hidden[/spoiler]`,
+      9,
+      23,
+    await fillIn(".d-editor-input", "Before this is hidden After");
+    textarea.selectionStart = 7;
+    textarea.selectionEnd = 21;
+      `Before [spoiler]this is hidden[/spoiler] After`,
+      16,
+      30,
+    await fillIn(".d-editor-input", "Before\nthis is hidden\nAfter");
+      `Before\n[spoiler]this is hidden[/spoiler]\nAfter`,
+      16,
+      30,
+    // enforce block mode when selected text is multiline
+    await fillIn(".d-editor-input", "Before\nthis is\n\nhidden\nAfter");
+    textarea.selectionEnd = 22;
+      `Before\n[spoiler]\nthis is\n\nhidden\n[/spoiler]\nAfter`,
+      17,
+      32,
diff --git a/test/javascripts/acceptance/spoiler-button-test.js.es6 b/test/javascripts/acceptance/spoiler-button-test.js.es6
deleted file mode 100644
index fd0b8e1..0000000
--- a/test/javascripts/acceptance/spoiler-button-test.js.es6
+++ /dev/null
@@ -1,143 +0,0 @@
-import I18n from "I18n";
-import selectKit from "discourse/tests/helpers/select-kit-helper";
-import { acceptance } from "discourse/tests/helpers/qunit-helpers";
-import { clearPopupMenuOptionsCallback } from "discourse/controllers/composer";
-acceptance("Spoiler Button", function (needs) {
-  needs.user();
-  needs.settings({ spoiler_enabled: true });
-  needs.hooks.beforeEach(() => {
-    clearPopupMenuOptionsCallback();
-  test("spoiler button", async (assert) => {
-    const popUpMenu = selectKit(".toolbar-popup-menu-options");
-    await visit("/");
-    assert.ok(exists("#create-topic"), "the create button is visible");
-    await click("#create-topic");
-    await popUpMenu.expand();
-    await popUpMenu.selectRowByValue("insertSpoiler");
-    assert.equal(
-      find(".d-editor-input").val(),
-      `[spoiler]${I18n.t("composer.spoiler_text")}[/spoiler]`,
-      "it should contain the right output"
-    let textarea = await find(".d-editor-input")[0];
-    assert.equal(
-      textarea.selectionStart,
-      9,
-      "it should start highlighting at the right position"
-    assert.equal(
-      textarea.selectionEnd,
-      I18n.t("composer.spoiler_text").length + 9,
-      "it should end highlighting at the right position"
-    await fillIn(".d-editor-input", "This is hidden");
-    textarea.selectionStart = 0;
-    textarea.selectionEnd = textarea.value.length;
-    assert.equal(
-      `[spoiler]This is hidden[/spoiler]`,
-    assert.equal(
-      9,
-    assert.equal(
-      23,
-    await fillIn(".d-editor-input", "Before this is hidden After");
-    textarea.selectionStart = 7;
-    textarea.selectionEnd = 21;
-    assert.equal(
-      `Before [spoiler]this is hidden[/spoiler] After`,
-    assert.equal(
-      16,
-    assert.equal(
-      30,
-    await fillIn(".d-editor-input", "Before\nthis is hidden\nAfter");
-    assert.equal(
-      `Before\n[spoiler]this is hidden[/spoiler]\nAfter`,
-    assert.equal(
-      16,
-    assert.equal(
-      30,
GitHub sha: 790380d9d321f9368c7a16d8ed87718fc6047bf2
This commit appears in #71 which was approved by martin. It was merged by CvX.
