DEV: Fix linting.
DEV: Fix linting.
diff --git a/assets/javascripts/discourse/connectors/user-preferences-account/encrypt.js.es6 b/assets/javascripts/discourse/connectors/user-preferences-account/encrypt.js.es6
index bcdd9a0..020a62e 100644
--- a/assets/javascripts/discourse/connectors/user-preferences-account/encrypt.js.es6
+++ b/assets/javascripts/discourse/connectors/user-preferences-account/encrypt.js.es6
@@ -123,7 +123,6 @@ export default {
         const publicStr = str[0].split(/\s+/).map(x => x.trim()).join("");
         const privateStr = str[1].split(/\s+/).map(x => x.trim()).join("");
-        console.log("importing key", publicStr, privateStr);
         keyPairPromise = Promise.all([
           importPublicKey(publicStr),
diff --git a/assets/javascripts/discourse/initializers/hook-draft.js.es6 b/assets/javascripts/discourse/initializers/hook-draft.js.es6
index 144988b..e9e619a 100644
--- a/assets/javascripts/discourse/initializers/hook-draft.js.es6
+++ b/assets/javascripts/discourse/initializers/hook-draft.js.es6
@@ -29,8 +29,6 @@ export default {
            * Encrypt private message drafts.
-          // TODO: Avoid using the container.
-          const container = Discourse.__container__;
           const controller = container.lookup("controller:composer");
           if (controller.get("model.isEncrypted")) {
             const p = getPublicKey();
GitHub sha: 4a3a9c14
