DEV: Fix search to be more intentional about what it is testing.
Asserting for the posts length is not accurate since an incorrect post can be returned and the assertion will still pass.
diff --git a/spec/components/search_spec.rb b/spec/components/search_spec.rb
index 3afe2c8..a1de5d4 100644
--- a/spec/components/search_spec.rb
+++ b/spec/components/search_spec.rb
@@ -190,16 +190,22 @@ describe Search do
   context 'private messages' do
+    let!(:topic) do
+      Fabricate(:topic, category_id: nil, archetype: 'private_message')
+    end
-    let(:topic) {
-      Fabricate(:topic,
-                  category_id: nil,
-                  archetype: 'private_message')
+    let!(:post) { Fabricate(:post, topic: topic) }
-    let(:post) { Fabricate(:post, topic: topic) }
-    let(:reply) { Fabricate(:post, topic: topic,
-                                   raw: 'hello from mars, we just landed') }
+    let!(:reply) do
+      Fabricate(:post, topic: topic, raw: 'hello from mars, we just landed')
+    end
+    let!(:post2) do
+      Fabricate(:post,
+        topic: Fabricate(:topic, category_id: nil, archetype: 'private_message'),
+        raw: 'another secret pm from mars, testing'
+    end
     it 'searches correctly' do
       expect do
@@ -209,41 +215,56 @@ describe Search do
       TopicAllowedUser.create!(user_id: reply.user_id, topic_id: topic.id)
       TopicAllowedUser.create!(user_id: post.user_id, topic_id: topic.id)
-      results = Search.execute('mars',
-                              type_filter: 'private_messages',
-                              guardian: Guardian.new(reply.user))
+      results = Search.execute(
+        'mars',
+        type_filter: 'private_messages',
+        guardian: Guardian.new(reply.user)
-      expect(results.posts.length).to eq(1)
+      expect(results.posts).to contain_exactly(reply)
-                              search_context: topic,
+        'mars',
+        guardian: Guardian.new(admin)
+      expect(results.posts).to contain_exactly(reply, post2)
-      # does not leak out
-                              guardian: Guardian.new(Fabricate(:user)))
+        'mars',
+        search_context: topic,
-      expect(results.posts.length).to eq(0)
-      Fabricate(:topic, category_id: nil, archetype: 'private_message')
-      Fabricate(:post, topic: topic, raw: 'another secret pm from mars, testing')
+      # does not leak out
+        'mars',
+        guardian: Guardian.new(Fabricate(:user))
+      expect(results.posts.empty?).to eq(true)
       # admin can search everything with correct context
-                              search_context: post.user,
-                              guardian: Guardian.new(admin))
+        'mars',
+        search_context: post.user,
-      results = Search.execute('mars in:private',
-                              guardian: Guardian.new(post.user))
+        'mars in:private',
+        guardian: Guardian.new(post.user)
       # can search group PMs as well as non admin
@@ -254,11 +275,12 @@ describe Search do
       TopicAllowedGroup.create!(group_id: group.id, topic_id: topic.id)
-                              guardian: Guardian.new(user))
+        guardian: Guardian.new(user)
     context 'personal-direct flag' do
@@ -341,55 +363,44 @@ describe Search do
         TopicAllowedUser.create!(user_id: u2.id, topic_id: private_topic.id)
         # private only
-        results = Search.execute('in:all cheese',
-                                guardian: Guardian.new(u1))
+        results = Search.execute('in:all cheese', guardian: Guardian.new(u1))
+        expect(results.posts).to contain_exactly(private_post1)
         # public only
-        results = Search.execute('in:all eggs',
+        results = Search.execute('in:all eggs', guardian: Guardian.new(u1))
+        expect(results.posts).to contain_exactly(public_post1)
         # both
-        results = Search.execute('in:all spam',
-        expect(results.posts.length).to eq(2)
+        results = Search.execute('in:all spam', guardian: Guardian.new(u1))
+        expect(results.posts).to contain_exactly(public_post2, private_post2)
         # for anon
-                                guardian: Guardian.new)
+        results = Search.execute('in:all spam', guardian: Guardian.new)
+        expect(results.posts).to contain_exactly(public_post2)
         # nonparticipatory user
-                                guardian: Guardian.new(u3))
+        results = Search.execute('in:all cheese', guardian: Guardian.new(u3))
+        results = Search.execute('in:all eggs', guardian: Guardian.new(u3))
+        results = Search.execute('in:all spam', guardian: Guardian.new(u3))
         # Admin doesn't see private topic
-                  guardian: Guardian.new(u4))
+        results = Search.execute('in:all spam', guardian: Guardian.new(u4))
         # same keyword for different users
-        results = Search.execute('in:all ham',
+        results = Search.execute('in:all ham', guardian: Guardian.new(u1))
+        expect(results.posts).to contain_exactly(public_post1, private_post1)
-                                guardian: Guardian.new(u2))
+        results = Search.execute('in:all ham', guardian: Guardian.new(u2))
GitHub sha: c2605d41
