DEV: Fix spec filename typo
diff --git a/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_iamges_spec.rb b/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_iamges_spec.rb
deleted file mode 100644
index 6543cbd..0000000
--- a/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_iamges_spec.rb
+++ /dev/null
@@ -1,44 +0,0 @@
-# frozen_string_literal: true
-require 'rails_helper'
-RSpec.describe Jobs::DiscourseNarrativeBot::RemapOldBotImages do
-  context "when bot's post contains an old link" do
-    let(:post) do
-      Fabricate(:post,
-        user: ::DiscourseNarrativeBot::Base.new.discobot_user,
-        raw: 'If you’d like to learn more, select <img src="/images/font-awesome-gear.png" width="16" height="16"> <img src="/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
-    end
-    before do
-      post
-    end
-    it 'should remap the links correctly' do
-      expected_raw = 'If you’d like to learn more, select <img src="/plugins/discourse-narrative-bot/images/font-awesome-gear.png" width="16" height="16"> <img src="/plugins/discourse-narrative-bot/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/plugins/discourse-narrative-bot/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
-      2.times do
-        described_class.new.execute_onceoff({})
-        expect(post.reload.raw).to eq(expected_raw)
-      end
-    end
-    context 'subfolder' do
-      let(:post) do
-        Fabricate(:post,
-          raw: 'If you’d like to learn more, select <img src="/community/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/community/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
-      end
-          'If you’d like to learn more, select <img src="/community/plugins/discourse-narrative-bot/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/community/plugins/discourse-narrative-bot/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
-      end
-    end
-  end
-end
diff --git a/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_images_spec.rb b/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_images_spec.rb
new file mode 100644
index 0000000..6543cbd
--- /dev/null
+++ b/plugins/discourse-narrative-bot/spec/jobs/onceoff/remap_old_bot_images_spec.rb
@@ -0,0 +1,44 @@
+require 'rails_helper'
+RSpec.describe Jobs::DiscourseNarrativeBot::RemapOldBotImages do
+  context "when bot's post contains an old link" do
+    let(:post) do
+      Fabricate(:post,
+        user: ::DiscourseNarrativeBot::Base.new.discobot_user,
+        raw: 'If you’d like to learn more, select <img src="/images/font-awesome-gear.png" width="16" height="16"> <img src="/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
+    end
+    before do
+      post
+    end
+    it 'should remap the links correctly' do
+      expected_raw = 'If you’d like to learn more, select <img src="/plugins/discourse-narrative-bot/images/font-awesome-gear.png" width="16" height="16"> <img src="/plugins/discourse-narrative-bot/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/plugins/discourse-narrative-bot/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
+      2.times do
+        described_class.new.execute_onceoff({})
+        expect(post.reload.raw).to eq(expected_raw)
+      end
+    end
+    context 'subfolder' do
+      let(:post) do
+        Fabricate(:post,
+          raw: 'If you’d like to learn more, select <img src="/community/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/community/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
+      end
+          'If you’d like to learn more, select <img src="/community/plugins/discourse-narrative-bot/images/font-awesome-ellipsis.png" width="16" height="16"> below  and <img src="/community/plugins/discourse-narrative-bot/images/font-awesome-bookmark.png" width="16" height="16"> **bookmark this private message**.  If you do, there may be a :gift: in your future!'
+      end
+    end
+  end
+end
GitHub sha: f875079b1ad02a88f9f33a93361bf0a7fa4898b1
This commit appears in #13317 which was approved by tgxworld. It was merged by tgxworld.
