DEV: Fix the broken build caused by 1e8f216.
diff --git a/spec/integration/topic_auto_close_spec.rb b/spec/integration/topic_auto_close_spec.rb
index 8dcc272..7b51b35 100644
--- a/spec/integration/topic_auto_close_spec.rb
+++ b/spec/integration/topic_auto_close_spec.rb
@@ -60,7 +60,7 @@ describe Topic do
             expect(topic_status_update.topic).to eq(staff_topic)
             expect(topic_status_update.execute_at).to eq_time(2.hours.from_now)
-            expect(topic_status_update.user).to eq(admin)
+            expect(topic_status_update.user).to eq(Discourse.system_user)
             args = job_klass.jobs.last['args'].first
GitHub sha: 83314d15
