DEV: Fix the `getURL` deprecation warning (#69)
DEV: Fix the getURL deprecation warning (#69)
diff --git a/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6 b/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
index aafda26..56b7534 100644
--- a/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
+++ b/assets/javascripts/discourse-assign/initializers/extend-for-assigns.js.es6
@@ -1,9 +1,8 @@
 import { renderAvatar } from "discourse/helpers/user-avatar";
 import { withPluginApi } from "discourse/lib/plugin-api";
-import { default as computed } from "discourse-common/utils/decorators";
-import { iconNode } from "discourse-common/lib/icon-library";
+import computed from "discourse-common/utils/decorators";
+import { iconHTML, iconNode } from "discourse-common/lib/icon-library";
 import { h } from "virtual-dom";
-import { iconHTML } from "discourse-common/lib/icon-library";
 import { queryRegistry } from "discourse/widgets/widget";
 import { getOwner } from "discourse-common/lib/get-owner";
 import getURL from "discourse-common/lib/get-url";
GitHub sha: 1a083e8b
This commit appears in #69 which was approved by eviltrout. It was merged by CvX.
