DEV: Fix undefined method due to rails_failover.
diff --git a/config/initializers/002-rails_failover.rb b/config/initializers/002-rails_failover.rb
index 16c5dc4..a7529a0 100644
--- a/config/initializers/002-rails_failover.rb
+++ b/config/initializers/002-rails_failover.rb
@@ -1,7 +1,5 @@
 # frozen_string_literal: true
-return unless Rails.configuration.active_record_rails_failover
 if defined?(RailsFailover::Redis)
   message_bus_keepalive_interval = nil
@@ -19,6 +17,8 @@ if defined?(RailsFailover::Redis)
 if defined?(RailsFailover::ActiveRecord)
+  return unless Rails.configuration.active_record_rails_failover
   if Rails.configuration.multisite
     if ActiveRecord::Base.current_role == ActiveRecord::Base.reading_role
       RailsMultisite::ConnectionManagement.default_connection_handler =
diff --git a/config/initializers/200-first_middlewares.rb b/config/initializers/200-first_middlewares.rb
index 3f2bce1..2467202 100644
--- a/config/initializers/200-first_middlewares.rb
+++ b/config/initializers/200-first_middlewares.rb
@@ -25,9 +25,9 @@ if Rails.configuration.multisite
   Rails.configuration.middleware.unshift RailsMultisite::Middleware, RailsMultisite::DiscoursePatches.config
   Rails.configuration.middleware.delete ActionDispatch::Executor
-  if defined?(RailsFailover) && Rails.configuration.active_record_rails_failover
+  if defined?(RailsFailover::ActiveRecord) && Rails.configuration.active_record_rails_failover
     Rails.configuration.middleware.insert_after(RailsMultisite::Middleware, RailsFailover::ActiveRecord::Middleware)
-elsif defined?(RailsFailover) && Rails.configuration.active_record_rails_failover
+elsif defined?(RailsFailover::ActiveRecord) && Rails.configuration.active_record_rails_failover
   Rails.configuration.middleware.insert_before(MessageBus::Rack::Middleware, RailsFailover::ActiveRecord::Middleware)
GitHub sha: b08a0d15
