DEV: Improve postgresql fallover and multisite tests.
diff --git a/lib/active_record/connection_adapters/postgresql_fallback_adapter.rb b/lib/active_record/connection_adapters/postgresql_fallback_adapter.rb
index 6016b16..3d4f9b2 100644
--- a/lib/active_record/connection_adapters/postgresql_fallback_adapter.rb
+++ b/lib/active_record/connection_adapters/postgresql_fallback_adapter.rb
@@ -68,6 +68,8 @@ class PostgreSQLFallbackHandler
         RailsMultisite::ConnectionManagement.with_connection(key) do
           begin
             logger.warn "#{log_prefix}: Checking master server..."
+            is_connection_active = false
             begin
               connection = ActiveRecord::Base.postgresql_connection(config)
               is_connection_active = connection.active?
@@ -99,7 +101,7 @@ class PostgreSQLFallbackHandler
   def clear_connections
-    ActiveRecord::Base.connection_pool.disconnect!
+    ActiveRecord::Base.clear_all_connections!
   private
diff --git a/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb b/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb
index 98a35de..5603609 100644
--- a/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb
+++ b/spec/components/active_record/connection_adapters/postgresql_fallback_adapter_spec.rb
@@ -27,23 +27,20 @@ describe ActiveRecord::ConnectionHandling do
   let(:postgresql_fallback_handler) { PostgreSQLFallbackHandler.instance }
   before do
-    # TODO: tgxworld will rewrite it without stubs
-    skip("Skip causes our build to be unstable")
     @threads = Thread.list
     postgresql_fallback_handler.initialized = true
-    ['default', multisite_db].each do |db|
-      postgresql_fallback_handler.master_up(db)
-    end
   after do
+    (Thread.list - @threads).each(&:kill)
     Sidekiq.unpause!
     postgresql_fallback_handler.setup!
     ActiveRecord::Base.unstub(:postgresql_connection)
-    (Thread.list - @threads).each(&:kill)
     ActiveRecord::Base.establish_connection
+    $redis.flushall
   describe "#postgresql_fallback_connection" do
@@ -55,32 +52,25 @@ describe ActiveRecord::ConnectionHandling do
     context 'when master server is down' do
-      before do
-        @replica_connection = mock('replica_connection')
-      end
-      after do
-        pg_readonly_mode_key = Discourse::PG_READONLY_MODE_KEY
-        with_multisite_db(multisite_db) do
-          Discourse.disable_readonly_mode(pg_readonly_mode_key)
-        end
-        ActiveRecord::Base.establish_connection(ActiveRecord::Base.configurations[Rails.env])
-      end
+      let(:replica_connection) { mock('replica_connection') }
       it 'should failover to a replica server' do
-        RailsMultisite::ConnectionManagement.stubs(:all_dbs).returns(['default', multisite_db])
+        RailsMultisite::ConnectionManagement
+          .stubs(:all_dbs)
+          .returns(['default', multisite_db])
         postgresql_fallback_handler.expects(:verify_master).at_least(3)
         [config, multisite_config].each do |configuration|
-          ActiveRecord::Base.expects(:postgresql_connection).with(configuration).raises(PG::ConnectionBad)
-          ActiveRecord::Base.expects(:verify_replica).with(@replica_connection)
+          ActiveRecord::Base.expects(:postgresql_connection)
+            .with(configuration)
+            .raises(PG::ConnectionBad)
+          ActiveRecord::Base.expects(:verify_replica).with(replica_connection)
             configuration.dup.merge(host: replica_host, port: replica_port)
-          ).returns(@replica_connection)
+          ).returns(replica_connection)
         expect(postgresql_fallback_handler.master_down?).to eq(nil)
@@ -109,8 +99,9 @@ describe ActiveRecord::ConnectionHandling do
             expect(message.data[:db]).to eq(multisite_db)
-            expect { ActiveRecord::Base.postgresql_fallback_connection(multisite_config) }
-              .to change { Discourse.readonly_mode? }.from(false).to(true)
+            expect do
+              ActiveRecord::Base.postgresql_fallback_connection(multisite_config)
+            end.to change { Discourse.readonly_mode? }.from(false).to(true)
             expect(postgresql_fallback_handler.master_down?).to eq(true)
           ensure
@@ -135,11 +126,17 @@ describe ActiveRecord::ConnectionHandling do
     context 'when both master and replica server is down' do
       it 'should raise the right error' do
-        ActiveRecord::Base.expects(:postgresql_connection).with(config).raises(PG::ConnectionBad)
-          config.dup.merge(host: replica_host, port: replica_port)
-        ).raises(PG::ConnectionBad).once
+          .with(config)
+          .once
+          .with(
+            config.dup.merge(host: replica_host, port: replica_port)
+          .once
         postgresql_fallback_handler.expects(:verify_master).twice
diff --git a/spec/rails_helper.rb b/spec/rails_helper.rb
index a0fad31..0d58507 100644
--- a/spec/rails_helper.rb
+++ b/spec/rails_helper.rb
@@ -179,14 +179,15 @@ RSpec.configure do |config|
   config.before(:each, type: :multisite) do
     Rails.configuration.multisite = true
     RailsMultisite::ConnectionManagement.config_filename =
       "spec/fixtures/multisite/two_dbs.yml"
   config.after(:each, type: :multisite) do
     Rails.configuration.multisite = false
     RailsMultisite::ConnectionManagement.clear_settings!
-    ActiveRecord::Base.clear_active_connections!
GitHub sha: ec58c33e
