DEV: Improve s3 upload image analysis
  • Introduces uploads:delete_missing_s3 which can be used to “give up” and delete broken records from the database
  • Fixes a bug in fix_missing_s3 - crashing on deleted posts
  • Adds more info to analyze_missing_s3
diff --git a/lib/tasks/uploads.rake b/lib/tasks/uploads.rake
index 416b8bf..9d6155e 100644
--- a/lib/tasks/uploads.rake
+++ b/lib/tasks/uploads.rake
@@ -1008,6 +1008,7 @@ def analyze_missing_s3
   lookup = {}
   other = []
   all = []
   DB.query(sql).each do |r|
     all << r
     if r.post_id
@@ -1028,7 +1029,8 @@ def analyze_missing_s3
     puts
-  puts "Total missing uploads: #{Upload.where(verified: false).count}"
+  missing_uploads = Upload.where(verified: false)
+  puts "Total missing uploads: #{missing_uploads.count}, newest is #{missing_uploads.maximum(:created_at)}"
   puts "Total problem posts: #{lookup.keys.count} with #{lookup.values.sum { |a| a.length } } missing uploads"
   puts "Other missing uploads count: #{other.count}"
@@ -1064,6 +1066,36 @@ def analyze_missing_s3
+def delete_missing_s3
+  missing = Upload.where(verified: false).order(:created_at)
+  count = missing.count
+  if count > 0
+    puts "The following uploads will be deleted from the database"
+    missing.each do |upload|
+      puts "#{upload.id} - #{upload.url} - #{upload.created_at}"
+    end
+    puts "Please confirm you wish to delete #{count} upload records by typing YES"
+    confirm = STDIN.gets.strip
+    if confirm == "YES"
+      missing.destroy_all
+      puts "#{count} records were deleted"
+    else
+      STDERR.puts "Aborting"
+      exit 1
+    end
+  end
+end
+task "uploads:delete_missing_s3" => :environment do
+  if RailsMultisite::ConnectionManagement.current_db != "default"
+    delete_missing_s3
+  else
+    RailsMultisite::ConnectionManagement.each_connection do
+      delete_missing_s3
+    end
+  end
+end
 task "uploads:analyze_missing_s3" => :environment do
     analyze_missing_s3
@@ -1138,9 +1170,13 @@ def fix_missing_s3
   SQL
   DB.query_single(sql).each do |post_id|
-    post = Post.find(post_id)
-    post.rebake!
-    print "."
+    post = Post.find_by(id: post_id)
+    if post
+      post.rebake!
+      print "."
+    else
+      puts "Skipping #{post_id} since it is deleted"
+    end
   puts
GitHub sha: f7314f8a
