DEV: jquery 3.4.0
DEV: jquery 3.4.0
diff --git a/package.json b/package.json
index 0746773..1d72bc5 100644
--- a/package.json
+++ b/package.json
@@ -16,7 +16,7 @@
     "highlight.js": "https://github.com/highlightjs/highlight.js",
     "htmlparser": "https://github.com/tautologistics/node-htmlparser",
     "intersection-observer": "^0.5.1",
-    "jquery": "3.3.1",
+    "jquery": "3.4.0",
     "jquery-color": "1.0.0",
     "jquery-resize": "https://github.com/cowboy/jquery-resize/",
     "jquery-tags-input": "1.3.5",
diff --git a/vendor/assets/javascripts/jquery.js b/vendor/assets/javascripts/jquery.js
index fe7c3fc..be2e6af 100644
--- a/vendor/assets/javascripts/jquery.js
+++ b/vendor/assets/javascripts/jquery.js
@@ -1,5 +1,5 @@
- * jQuery JavaScript Library v3.3.1
+ * jQuery JavaScript Library v3.4.0
  * https://jquery.com/
  * Includes Sizzle.js
@@ -9,7 +9,7 @@
  * Released under the MIT license
  * https://jquery.org/license
- * Date: 2018-01-20T17:24Z
+ * Date: 2019-04-10T19:48Z
 ( function( global, factory ) {
@@ -91,20 +91,33 @@ var isWindow = function isWindow( obj ) {
 	var preservedScriptAttributes = {
 		type: true,
 		src: true,
+		nonce: true,
 		noModule: true
-	function DOMEval( code, doc, node ) {
+	function DOMEval( code, node, doc ) {
 		doc = doc || document;
-		var i,
+		var i, val,
 			script = doc.createElement( "script" );
 		script.text = code;
 		if ( node ) {
 			for ( i in preservedScriptAttributes ) {
-				if ( node[ i ] ) {
-					script[ i ] = node[ i ];
+				// Support: Firefox 64+, Edge 18+
+				// Some browsers don't support the "nonce" property on scripts.
+				// On the other hand, just using `getAttribute` is not enough as
+				// the `nonce` attribute is reset to an empty string whenever it
+				// becomes browsing-context connected.
+				// See https://github.com/whatwg/html/issues/2369
+				// See https://html.spec.whatwg.org/#nonce-attributes
+				// The `node.getAttribute` check was added for the sake of
+				// `jQuery.globalEval` so that it can fake a nonce-containing node
+				// via an object.
+				val = node[ i ] || node.getAttribute && node.getAttribute( i );
+				if ( val ) {
+					script.setAttribute( i, val );
@@ -129,7 +142,7 @@ function toType( obj ) {
 var
-	version = "3.3.1",
+	version = "3.4.0",
 	// Define a local copy of jQuery
 	jQuery = function( selector, context ) {
@@ -258,26 +271,28 @@ jQuery.extend = jQuery.fn.extend = function() {
 			// Extend the base object
 			for ( name in options ) {
-				src = target[ name ];
 				copy = options[ name ];
 				// Prevent Object.prototype pollution
 				// Prevent never-ending loop
-				if ( name === "__proto__" || target === copy  ) {
+				if ( name === "__proto__" || target === copy ) {
 					continue;
 				// Recurse if we're merging plain objects or arrays
 				if ( deep && copy && ( jQuery.isPlainObject( copy ) ||
 					( copyIsArray = Array.isArray( copy ) ) ) ) {
+					src = target[ name ];
-					if ( copyIsArray ) {
-						copyIsArray = false;
-						clone = src && Array.isArray( src ) ? src : [];
+					// Ensure proper type for the source value
+					if ( copyIsArray && !Array.isArray( src ) ) {
+						clone = [];
+					} else if ( !copyIsArray && !jQuery.isPlainObject( src ) ) {
+						clone = {};
 					} else {
-						clone = src && jQuery.isPlainObject( src ) ? src : {};
+						clone = src;
+					copyIsArray = false;
 					// Never move original objects, clone them
 					target[ name ] = jQuery.extend( deep, clone, copy );
@@ -330,9 +345,6 @@ jQuery.extend( {
 	isEmptyObject: function( obj ) {
-		/* eslint-disable no-unused-vars */
-		// See https://github.com/eslint/eslint/issues/6125
 		var name;
 		for ( name in obj ) {
@@ -342,8 +354,8 @@ jQuery.extend( {
 	// Evaluates a script in a global context
-	globalEval: function( code ) {
-		DOMEval( code );
+	globalEval: function( code, options ) {
+		DOMEval( code, { nonce: options && options.nonce } );
 	each: function( obj, callback ) {
@@ -499,14 +511,14 @@ function isArrayLike( obj ) {
 var Sizzle =
- * Sizzle CSS Selector Engine v2.3.3
+ * Sizzle CSS Selector Engine v2.3.4
  * https://sizzlejs.com/
- * Copyright jQuery Foundation and other contributors
+ * Copyright JS Foundation and other contributors
- * http://jquery.org/license
+ * https://js.foundation/
- * Date: 2016-08-08
+ * Date: 2019-04-08
 (function( window ) {
@@ -540,6 +552,7 @@ var i,
 	classCache = createCache(),
 	tokenCache = createCache(),
 	compilerCache = createCache(),
+	nonnativeSelectorCache = createCache(),
 	sortOrder = function( a, b ) {
 		if ( a === b ) {
 			hasDuplicate = true;
@@ -601,8 +614,7 @@ var i,
 	rcomma = new RegExp( "^" + whitespace + "*," + whitespace + "*" ),
 	rcombinators = new RegExp( "^" + whitespace + "*([>+~]|" + whitespace + ")" + whitespace + "*" ),
-	rattributeQuotes = new RegExp( "=" + whitespace + "*([^\\]'\"]*?)" + whitespace + "*\\]", "g" ),
+	rdescend = new RegExp( whitespace + "|>" ),
 	rpseudo = new RegExp( pseudos ),
 	ridentifier = new RegExp( "^" + identifier + "$" ),
@@ -623,6 +635,7 @@ var i,
 			whitespace + "*((?:-\\d)?\\d*)" + whitespace + "*\\)|)(?=[^-]|$)", "i" )
+	rhtml = /HTML$/i,
 	rinputs = /^(?:input|select|textarea|button)$/i,
 	rheader = /^h\d$/i,
@@ -677,9 +690,9 @@ var i,
 		setDocument();
-	disabledAncestor = addCombinator(
+	inDisabledFieldset = addCombinator(
 		function( elem ) {
-			return elem.disabled === true && ("form" in elem || "label" in elem);
+			return elem.disabled === true && elem.nodeName.toLowerCase() === "fieldset";
 		{ dir: "parentNode", next: "legend" }
@@ -792,18 +805,22 @@ function Sizzle( selector, context, results, seed ) {
 			// Take advantage of querySelectorAll
 			if ( support.qsa &&
-				!compilerCache[ selector + " " ] &&
-				(!rbuggyQSA || !rbuggyQSA.test( selector )) ) {
-				if ( nodeType !== 1 ) {
-					newContext = context;
-					newSelector = selector;
+				!nonnativeSelectorCache[ selector + " " ] &&
+				(!rbuggyQSA || !rbuggyQSA.test( selector )) &&
-				// qSA looks outside Element context, which is not what we want
-				// Thanks to Andrew Dupont for this workaround technique
-				// Support: IE <=8
+				// Support: IE 8 only
 				// Exclude object elements
-				} else if ( context.nodeName.toLowerCase() !== "object" ) {
+				(nodeType !== 1 || context.nodeName.toLowerCase() !== "object") ) {
+				newSelector = selector;
+				newContext = context;
+				// qSA considers elements outside a scoping root when evaluating child or
+				// descendant combinators, which is not what we want.
+				// In such cases, we work around the behavior by prefixing every selector in the
+				// list with an ID selector referencing the scope context.
+				// Thanks to Andrew Dupont for this technique.
+				if ( nodeType === 1 && rdescend.test( selector ) ) {
 					// Capture the context ID, setting it first if necessary
 					if ( (nid = context.getAttribute( "id" )) ) {
@@ -825,17 +842,16 @@ function Sizzle( selector, context, results, seed ) {
 						context;
-				if ( newSelector ) {
-					try {
-						push.apply( results,
-							newContext.querySelectorAll( newSelector )
-						return results;
-					} catch ( qsaError ) {
-					} finally {
-						if ( nid === expando ) {
-							context.removeAttribute( "id" );
+				try {
+					push.apply( results,
+						newContext.querySelectorAll( newSelector )
+					return results;
+				} catch ( qsaError ) {
+					nonnativeSelectorCache( selector, true );
+				} finally {
+					if ( nid === expando ) {
+						context.removeAttribute( "id" );
@@ -999,7 +1015,7 @@ function createDisabledPseudo( disabled ) {
 					// Where there is no isDisabled, check manually
 					/* jshint -W018 */
 					elem.isDisabled !== !disabled &&
-						disabledAncestor( elem ) === disabled;
GitHub sha: 9f07ced6
