DEV: jquery 3.4.1 (#7470)
diff --git a/package.json b/package.json
index 1d72bc5..f409d94 100644
--- a/package.json
+++ b/package.json
@@ -16,7 +16,7 @@
     "highlight.js": "https://github.com/highlightjs/highlight.js",
     "htmlparser": "https://github.com/tautologistics/node-htmlparser",
     "intersection-observer": "^0.5.1",
-    "jquery": "3.4.0",
+    "jquery": "3.4.1",
     "jquery-color": "1.0.0",
     "jquery-resize": "https://github.com/cowboy/jquery-resize/",
     "jquery-tags-input": "1.3.5",
diff --git a/vendor/assets/javascripts/jquery.js b/vendor/assets/javascripts/jquery.js
index be2e6af..773ad95 100644
--- a/vendor/assets/javascripts/jquery.js
+++ b/vendor/assets/javascripts/jquery.js
@@ -1,5 +1,5 @@
- * jQuery JavaScript Library v3.4.0
+ * jQuery JavaScript Library v3.4.1
  * https://jquery.com/
  * Includes Sizzle.js
@@ -9,7 +9,7 @@
  * Released under the MIT license
  * https://jquery.org/license
- * Date: 2019-04-10T19:48Z
+ * Date: 2019-05-01T21:04Z
 ( function( global, factory ) {
@@ -142,7 +142,7 @@ function toType( obj ) {
 var
-	version = "3.4.0",
+	version = "3.4.1",
 	// Define a local copy of jQuery
 	jQuery = function( selector, context ) {
@@ -4498,8 +4498,12 @@ var documentElement = document.documentElement;
 		composed = { composed: true };
+	// Support: IE 9 - 11+, Edge 12 - 18+, iOS 10.0 - 10.2 only
 	// Check attachment across shadow DOM boundaries when possible (gh-3504)
-	if ( documentElement.attachShadow ) {
+	// Support: iOS 10.0-10.2 only
+	// Early iOS 10 versions support `attachShadow` but not `getRootNode`,
+	// leading to errors. We need to check for `getRootNode`.
+	if ( documentElement.getRootNode ) {
 		isAttached = function( elem ) {
 			return jQuery.contains( elem.ownerDocument, elem ) ||
 				elem.getRootNode( composed ) === elem.ownerDocument;
@@ -5359,8 +5363,7 @@ jQuery.event = {
 				// Claim the first handler
 				if ( rcheckableType.test( el.type ) &&
-					el.click && nodeName( el, "input" ) &&
-					dataPriv.get( el, "click" ) === undefined ) {
+					el.click && nodeName( el, "input" ) ) {
 					// dataPriv.set( el, "click", ... )
 					leverageNative( el, "click", returnTrue );
@@ -5377,8 +5380,7 @@ jQuery.event = {
 				// Force setup before triggering a click
 					leverageNative( el, "click" );
@@ -5419,7 +5421,9 @@ function leverageNative( el, type, expectSync ) {
 	// Missing expectSync indicates a trigger call, which must force setup through jQuery.event.add
 	if ( !expectSync ) {
-		jQuery.event.add( el, type, returnTrue );
+		if ( dataPriv.get( el, type ) === undefined ) {
+			jQuery.event.add( el, type, returnTrue );
 		return;
@@ -5434,9 +5438,13 @@ function leverageNative( el, type, expectSync ) {
 			if ( ( event.isTrigger & 1 ) && this[ type ] ) {
 				// Interrupt processing of the outer synthetic .trigger()ed event
-				if ( !saved ) {
+				// Saved data should be false in such cases, but might be a leftover capture object
+				// from an async native handler (gh-4350)
+				if ( !saved.length ) {
 					// Store arguments for use when handling the inner native event
+					// There will always be at least one argument (an event object), so this array
+					// will not be confused with a leftover capture object.
 					saved = slice.call( arguments );
 					dataPriv.set( this, type, saved );
@@ -5449,14 +5457,14 @@ function leverageNative( el, type, expectSync ) {
 					if ( saved !== result || notAsync ) {
 						dataPriv.set( this, type, false );
 					} else {
-						result = undefined;
+						result = {};
 					if ( saved !== result ) {
 						// Cancel the outer synthetic event
 						event.stopImmediatePropagation();
 						event.preventDefault();
-						return result;
+						return result.value;
 				// If this is an inner synthetic event for an event with a bubbling surrogate
@@ -5471,17 +5479,19 @@ function leverageNative( el, type, expectSync ) {
 			// If this is a native event triggered above, everything is now in order
 			// Fire an inner synthetic event with the original arguments
-			} else if ( saved ) {
+			} else if ( saved.length ) {
 				// ...and capture the result
-				dataPriv.set( this, type, jQuery.event.trigger(
-					// Support: IE <=9 - 11+
-					// Extend with the prototype to reset the above stopImmediatePropagation()
-					jQuery.extend( saved.shift(), jQuery.Event.prototype ),
-					saved,
-					this
+				dataPriv.set( this, type, {
+					value: jQuery.event.trigger(
+						// Support: IE <=9 - 11+
+						// Extend with the prototype to reset the above stopImmediatePropagation()
+						jQuery.extend( saved[ 0 ], jQuery.Event.prototype ),
+						saved.slice( 1 ),
+						this
 				// Abort handling of the native event
diff --git a/yarn.lock b/yarn.lock
index a32da8c..4fb8d8d 100644
--- a/yarn.lock
+++ b/yarn.lock
@@ -1364,10 +1364,10 @@ jquery.cookie@1.4.1:
   resolved "https://registry.yarnpkg.com/jquery.cookie/-/jquery.cookie-1.4.1.tgz#d63dce209eab691fe63316db08ca9e47e0f9385b"
   integrity sha1-1j3OIJ6raR/mMxbbCMqeR+D5OFs=
-jquery@3.4.0:
-  version "3.4.0"
-  resolved "https://registry.yarnpkg.com/jquery/-/jquery-3.4.0.tgz#8de513fa0fa4b2c7d2e48a530e26f0596936efdf"
-  integrity sha512-ggRCXln9zEqv6OqAGXFEcshF5dSBvCkzj6Gm2gzuR5fWawaX8t7cxKVkkygKODrDAzKdoYw3l/e3pm3vlT4IbQ==
+jquery@3.4.1:
+  version "3.4.1"
+  resolved "https://registry.yarnpkg.com/jquery/-/jquery-3.4.1.tgz#714f1f8d9dde4bdfa55764ba37ef214630d80ef2"
+  integrity sha512-36+AdBzCL+y6qjw5Tx7HgzeGCzC81MDDgaUP8ld2zhx58HdqXGoBd+tHdrBMiyjGQs0Hxs/MLZTu/eHNJJuWPw==
 js-reporters@1.2.1:
   version "1.2.1"
GitHub sha: 4c444592
