DEV: Leaking state in `PostActionNotifier` in tests take 2.
DEV: Leaking state in PostActionNotifier in tests take 2.
Follow-up to a3b48826
diff --git a/app/services/post_action_notifier.rb b/app/services/post_action_notifier.rb
index 7644611..3f562e3 100644
--- a/app/services/post_action_notifier.rb
+++ b/app/services/post_action_notifier.rb
@@ -4,13 +4,17 @@ class PostActionNotifier
   def self.disable
     @disabled = true
-    @custom_post_revision_notifier_recipients = nil
   def self.enable
     @disabled = false
+  # For testing purposes
+  def self.reset!
+    @custom_post_revision_notifier_recipients = nil
+  end
   def self.alerter
     @alerter ||= PostAlerter.new
diff --git a/spec/services/post_action_notifier_spec.rb b/spec/services/post_action_notifier_spec.rb
index 746c193..00d326e 100644
--- a/spec/services/post_action_notifier_spec.rb
+++ b/spec/services/post_action_notifier_spec.rb
@@ -108,6 +108,10 @@ describe PostActionNotifier do
+      after do
+        PostActionNotifier.reset!
+      end
       it 'notifies the specified user of the revision' do
         expect {
           post.revise(evil_trout, raw: "world is the new body of the message")
GitHub sha: 5270cd97
