DEV: Leaking state in `PostActionNotifier` in tests.
DEV: Leaking state in PostActionNotifier in tests.
Follow-up to 8a0478b97d
diff --git a/app/services/post_action_notifier.rb b/app/services/post_action_notifier.rb
index 909e263..7644611 100644
--- a/app/services/post_action_notifier.rb
+++ b/app/services/post_action_notifier.rb
@@ -4,6 +4,7 @@ class PostActionNotifier
   def self.disable
     @disabled = true
+    @custom_post_revision_notifier_recipients = nil
   def self.enable
diff --git a/spec/services/post_action_notifier_spec.rb b/spec/services/post_action_notifier_spec.rb
index dda4413..746c193 100644
--- a/spec/services/post_action_notifier_spec.rb
+++ b/spec/services/post_action_notifier_spec.rb
@@ -108,10 +108,6 @@ describe PostActionNotifier do
-      after do
-        DiscoursePluginRegistry.reset!
-      end
       it 'notifies the specified user of the revision' do
         expect {
           post.revise(evil_trout, raw: "world is the new body of the message")
GitHub sha: a3b48826
