DEV: linting
DEV: linting
diff --git a/assets/javascripts/discourse/components/json-file-uploader.js.es6 b/assets/javascripts/discourse/components/json-file-uploader.js.es6
index 4ab4cfd..95a2aa4 100644
--- a/assets/javascripts/discourse/components/json-file-uploader.js.es6
+++ b/assets/javascripts/discourse/components/json-file-uploader.js.es6
@@ -21,21 +21,29 @@ export default Ember.Component.extend({
     $(fileInput).on("change", () => this.fileSelected(fileInput.files));
     $this.on("dragover", (e) => {
-      if (e.preventDefault) e.preventDefault();
+      if (e.preventDefault) {
+        e.preventDefault();
       return false;
     $this.on("dragenter", (e) => {
       this.set("hover", this.hover + 1);
       return false;
     $this.on("dragleave", (e) => {
       this.set("hover", this.hover - 1);
       return false;
     $this.on("drop", (e) => {
       this.set("hover", 0);
       this.fileSelected(e.dataTransfer.files);
diff --git a/assets/javascripts/discourse/components/param-input.js.es6 b/assets/javascripts/discourse/components/param-input.js.es6
index 0369054..e6947db 100644
--- a/assets/javascripts/discourse/components/param-input.js.es6
+++ b/assets/javascripts/discourse/components/param-input.js.es6
@@ -101,7 +101,9 @@ export default Ember.Component.extend({
           return !!this.site.categories.find((c) => c.id === intVal);
         } else if (/\//.test(value)) {
           const match = /(.*)\/(.*)/.exec(value);
-          if (!match) return false;
+          if (!match) {
+            return false;
           const result = Category.findBySlug(
             match[2].dasherize(),
             match[1].dasherize()
diff --git a/assets/javascripts/discourse/controllers/admin-plugins-explorer.js.es6 b/assets/javascripts/discourse/controllers/admin-plugins-explorer.js.es6
index 07dd278..7a4e3e7 100644
--- a/assets/javascripts/discourse/controllers/admin-plugins-explorer.js.es6
+++ b/assets/javascripts/discourse/controllers/admin-plugins-explorer.js.es6
@@ -97,8 +97,9 @@ export default Ember.Controller.extend({
   save() {
     this.set("loading", true);
-    if (this.get("selectedItem.description") === "")
+    if (this.get("selectedItem.description") === "") {
       this.set("selectedItem.description", "");
     return this.selectedItem
       .save()
@@ -202,8 +203,9 @@ export default Ember.Controller.extend({
         .then((result) => {
           const query = this.get("selectedItem");
           query.setProperties(result.getProperties(Query.updatePropertyNames));
-          if (!query.group_ids || !Array.isArray(query.group_ids))
+          if (!query.group_ids || !Array.isArray(query.group_ids)) {
             query.set("group_ids", []);
           query.markNotDirty();
           this.set("editing", false);
diff --git a/package.json b/package.json
index f63217c..93fcb8b 100644
--- a/package.json
+++ b/package.json
@@ -1,5 +1,5 @@
   "dependencies": {
-    "eslint-config-discourse": "latest"
+    "eslint-config-discourse": "^1.1.4"
diff --git a/yarn.lock b/yarn.lock
index 0faf4e3..3f25bf0 100644
--- a/yarn.lock
+++ b/yarn.lock
@@ -2,96 +2,95 @@
 # yarn lockfile v1
-"@babel/code-frame@^7.0.0", "@babel/code-frame@^7.10.1":
-  version "7.10.1"
-  resolved "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.10.1.tgz#d5481c5095daa1c57e16e54c6f9198443afb49ff"
-  integrity sha512-IGhtTmpjGbYzcEDOw7DcQtbQSXcG9ftmAXtWTu9V936vDye4xjjekktFAtgZsWpzTj/X01jocB46mTywm/4SZw==
+"@babel/code-frame@^7.0.0", "@babel/code-frame@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.10.4.tgz#168da1a36e90da68ae8d49c0f1b48c7c6249213a"
+  integrity sha512-vG6SvB6oYEhvgisZNFRmRCUkLz11c7rp+tbNTynGqc6mS1d5ATd/sGyV6W0KZZnXRKMTzZDRgQT3Ou9jhpAfUg==
   dependencies:
-    "@babel/highlight" "^7.10.1"
+    "@babel/highlight" "^7.10.4"
-"@babel/generator@^7.10.1":
-  version "7.10.1"
-  resolved "https://registry.yarnpkg.com/@babel/generator/-/generator-7.10.1.tgz#4d14458e539bcb04ffe34124143f5c489f2dbca9"
-  integrity sha512-AT0YPLQw9DI21tliuJIdplVfLHya6mcGa8ctkv7n4Qv+hYacJrKmNWIteAK1P9iyLikFIAkwqJ7HAOqIDLFfgA==
+"@babel/generator@^7.11.5":
+  version "7.11.6"
+  resolved "https://registry.yarnpkg.com/@babel/generator/-/generator-7.11.6.tgz#b868900f81b163b4d464ea24545c61cbac4dc620"
+  integrity sha512-DWtQ1PV3r+cLbySoHrwn9RWEgKMBLLma4OBQloPRyDYvc5msJM9kvTLo1YnlJd1P/ZuKbdli3ijr5q3FvAF3uA==
   dependencies:
-    "@babel/types" "^7.10.1"
+    "@babel/types" "^7.11.5"
     jsesc "^2.5.1"
-    lodash "^4.17.13"
     source-map "^0.5.0"
-"@babel/helper-function-name@^7.10.1":
-  version "7.10.1"
-  resolved "https://registry.yarnpkg.com/@babel/helper-function-name/-/helper-function-name-7.10.1.tgz#92bd63829bfc9215aca9d9defa85f56b539454f4"
-  integrity sha512-fcpumwhs3YyZ/ttd5Rz0xn0TpIwVkN7X0V38B9TWNfVF42KEkhkAAuPCQ3oXmtTRtiPJrmZ0TrfS0GKF0eMaRQ==
+"@babel/helper-function-name@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/helper-function-name/-/helper-function-name-7.10.4.tgz#d2d3b20c59ad8c47112fa7d2a94bc09d5ef82f1a"
+  integrity sha512-YdaSyz1n8gY44EmN7x44zBn9zQ1Ry2Y+3GTA+3vH6Mizke1Vw0aWDM66FOYEPw8//qKkmqOckrGgTYa+6sceqQ==
   dependencies:
-    "@babel/helper-get-function-arity" "^7.10.1"
-    "@babel/template" "^7.10.1"
+    "@babel/helper-get-function-arity" "^7.10.4"
+    "@babel/template" "^7.10.4"
+    "@babel/types" "^7.10.4"
-"@babel/helper-get-function-arity@^7.10.1":
-  version "7.10.1"
-  resolved "https://registry.yarnpkg.com/@babel/helper-get-function-arity/-/helper-get-function-arity-7.10.1.tgz#7303390a81ba7cb59613895a192b93850e373f7d"
-  integrity sha512-F5qdXkYGOQUb0hpRaPoetF9AnsXknKjWMZ+wmsIRsp5ge5sFh4c3h1eH2pRTTuy9KKAA2+TTYomGXAtEL2fQEw==
+"@babel/helper-get-function-arity@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/helper-get-function-arity/-/helper-get-function-arity-7.10.4.tgz#98c1cbea0e2332f33f9a4661b8ce1505b2c19ba2"
+  integrity sha512-EkN3YDB+SRDgiIUnNgcmiD361ti+AVbL3f3Henf6dqqUyr5dMsorno0lJWJuLhDhkI5sYEpgj6y9kB8AOU1I2A==
   dependencies:
-"@babel/helper-split-export-declaration@^7.10.1":
-  version "7.10.1"
-  resolved "https://registry.yarnpkg.com/@babel/helper-split-export-declaration/-/helper-split-export-declaration-7.10.1.tgz#c6f4be1cbc15e3a868e4c64a17d5d31d754da35f"
-  integrity sha512-UQ1LVBPrYdbchNhLwj6fetj46BcFwfS4NllJo/1aJsT+1dLTEnXJL0qHqtY7gPzF8S2fXBJamf1biAXV3X077g==
+"@babel/helper-split-export-declaration@^7.11.0":
+  version "7.11.0"
+  resolved "https://registry.yarnpkg.com/@babel/helper-split-export-declaration/-/helper-split-export-declaration-7.11.0.tgz#f8a491244acf6a676158ac42072911ba83ad099f"
+  integrity sha512-74Vejvp6mHkGE+m+k5vHY93FX2cAtrw1zXrZXRlG4l410Nm9PxfEiVTn1PjDPV5SnmieiueY4AFg2xqhNFuuZg==
   dependencies:
+    "@babel/types" "^7.11.0"
-"@babel/helper-validator-identifier@^7.10.1":
-  version "7.10.1"
-  resolved "https://registry.yarnpkg.com/@babel/helper-validator-identifier/-/helper-validator-identifier-7.10.1.tgz#5770b0c1a826c4f53f5ede5e153163e0318e94b5"
-  integrity sha512-5vW/JXLALhczRCWP0PnFDMCJAchlBvM7f4uk/jXritBnIa6E1KmqmtrS3yn1LAnxFBypQ3eneLuXjsnfQsgILw==
+"@babel/helper-validator-identifier@^7.10.4":
+  version "7.10.4"
+  resolved "https://registry.yarnpkg.com/@babel/helper-validator-identifier/-/helper-validator-identifier-7.10.4.tgz#a78c7a7251e01f616512d31b10adcf52ada5e0d2"
GitHub sha: 6205bb85
