DEV: load styleguide assets only when needed (#10918)
diff --git a/app/assets/javascripts/discourse/app/lib/url.js b/app/assets/javascripts/discourse/app/lib/url.js
index c5ecda5..335f33c 100644
--- a/app/assets/javascripts/discourse/app/lib/url.js
+++ b/app/assets/javascripts/discourse/app/lib/url.js
@@ -34,6 +34,7 @@ const SERVER_SIDE_ONLY = [
   /^\/admin\/logs\/watched_words\/action\/[^\/]+\/download$/,
   /^\/pub\//,
   /^\/invites\//,
+  /^\/styleguide\//,
 // The amount of height (in pixles) that we factor in when jumpEnd is called so
diff --git a/plugins/styleguide/plugin.rb b/plugins/styleguide/plugin.rb
index 47a5d7c..2e07033 100644
--- a/plugins/styleguide/plugin.rb
+++ b/plugins/styleguide/plugin.rb
@@ -13,3 +13,9 @@ load File.expand_path('../lib/styleguide/engine.rb', __FILE__)
 Discourse::Application.routes.append do
   mount ::Styleguide::Engine, at: '/styleguide'
+after_initialize do
+  register_asset_filter do |type, request|
+    request&.fullpath&.start_with?('/styleguide')
+  end
+end
diff --git a/plugins/styleguide/spec/integration/assets_spec.rb b/plugins/styleguide/spec/integration/assets_spec.rb
new file mode 100644
index 0000000..562730b
--- /dev/null
+++ b/plugins/styleguide/spec/integration/assets_spec.rb
@@ -0,0 +1,24 @@
+require 'rails_helper'
+describe 'Styleguide assets' do
+  before do
+    SiteSetting.styleguide_enabled = true
+    sign_in(Fabricate(:admin))
+  end
+  context 'visits homepage' do
+    it 'doesn’t load styleguide assets' do
+      get '/'
+      expect(response.body).to_not include('styleguide')
+    end
+  end
+  context 'visits styleguide' do
+    it 'loads styleguide assets' do
+      get '/styleguide'
+      expect(response.body).to include('styleguide')
+    end
+  end
+end
GitHub sha: 73d207a5
This commit appears in #10918 which was approved by davidtaylorhq. It was merged by jjaffeux.
