DEV: Maintain github_user_info primary key values during migration (#11286)
This will only happen if the user_associated_accounts table is currently empty. It’s useful for people that may be depending on primary key values in data explorer queries. This change will only have an effect on sites which have not already run this migration.
diff --git a/db/migrate/20201109170951_migrate_github_user_infos.rb b/db/migrate/20201109170951_migrate_github_user_infos.rb
index 8803d06..b93d9a4 100644
--- a/db/migrate/20201109170951_migrate_github_user_infos.rb
+++ b/db/migrate/20201109170951_migrate_github_user_infos.rb
@@ -2,6 +2,11 @@
 class MigrateGithubUserInfos < ActiveRecord::Migration[6.0]
   def up
+    # If the user_associated_accounts table is currently empty,
+    # maintain the primary key from github_user_infos
+    # This is useful for people that are using data explorer to access the data
+    maintain_ids = DB.query_single("SELECT count(*) FROM user_associated_accounts")[0] == 0
     execute <<~SQL
       INSERT INTO user_associated_accounts (
         provider_name,
@@ -11,6 +16,7 @@ class MigrateGithubUserInfos < ActiveRecord::Migration[6.0]
         last_used,
         created_at,
         updated_at
+        #{", id" if maintain_ids}
       ) SELECT
         'github',
         github_user_id,
@@ -19,8 +25,18 @@ class MigrateGithubUserInfos < ActiveRecord::Migration[6.0]
         updated_at,
         created_at,
         updated_at
       FROM github_user_infos
     SQL
+    if maintain_ids
+      execute <<~SQL
+        SELECT setval(
+          pg_get_serial_sequence('user_associated_accounts', 'id'),
+          (select greatest(max(id), 1) from user_associated_accounts)
+      SQL
+    end
   def down
GitHub sha: 02278109
This commit appears in #11286 which was approved by nbianca. It was merged by davidtaylorhq.
