DEV: Make attachment markdown reusable
diff --git a/app/jobs/regular/export_csv_file.rb b/app/jobs/regular/export_csv_file.rb
index d8d3a72..4db9fd2 100644
--- a/app/jobs/regular/export_csv_file.rb
+++ b/app/jobs/regular/export_csv_file.rb
@@ -4,12 +4,11 @@ require 'csv'
 require 'zip'
 require_dependency 'system_message'
 require_dependency 'upload_creator'
+require_dependency 'discourse_markdown'
 module Jobs
   class ExportCsvFile < Jobs::Base
-    include ActionView::Helpers::NumberHelper
     sidekiq_options retry: false
     HEADER_ATTRS_FOR ||= HashWithIndifferentAccess.new(
@@ -406,7 +405,7 @@ module Jobs
           SystemMessage.create_from_system_user(
             @current_user,
             :csv_export_succeeded,
-            download_link: "[#{upload.original_filename}|attachment](#{upload.short_url}) (#{number_to_human_size(upload.filesize)})",
+            download_link: DiscourseMarkdown.attachment_markdown(upload),
             export_title: export_title
         else
diff --git a/lib/discourse_markdown.rb b/lib/discourse_markdown.rb
new file mode 100644
index 0000000..8200372
--- /dev/null
+++ b/lib/discourse_markdown.rb
@@ -0,0 +1,24 @@
+require_dependency "file_helper"
+class DiscourseMarkdown
+  def self.upload_markdown(upload, display_name: nil)
+    if FileHelper.is_supported_image?(upload.original_filename)
+      image_markdown(upload)
+    else
+      attachment_markdown(upload, display_name: display_name)
+    end
+  end
+  def self.image_markdown(upload)
+    "![#{upload.original_filename}|#{upload.width}x#{upload.height}](#{upload.short_url})"
+  end
+  def self.attachment_markdown(upload, display_name: nil, with_filesize: true)
+    human_filesize = with_filesize ? " (#{upload.human_filesize})" : ""
+    display_name ||= upload.original_filename
+    "[#{display_name}|attachment](#{upload.short_url})#{human_filesize}"
+  end
+end
diff --git a/lib/email/receiver.rb b/lib/email/receiver.rb
index 18452eb..04882bb 100644
--- a/lib/email/receiver.rb
+++ b/lib/email/receiver.rb
@@ -5,12 +5,11 @@ require_dependency "new_post_manager"
 require_dependency "html_to_markdown"
 require_dependency "plain_text_to_markdown"
 require_dependency "upload_creator"
+require_dependency "discourse_markdown"
 module Email
   class Receiver
     # If you add a new error, you need to
     #   * add it to Email::Processor#handle_failure()
     #   * add text to server.en.yml (parent key: "emails.incoming.errors")
@@ -1035,19 +1034,16 @@ module Email
                 InlineUploads.match_img(raw) do |match, src, replacement, _|
                   if src == upload.url
-                    raw = raw.sub(
-                      match,
-                      "![#{upload.original_filename}|#{upload.width}x#{upload.height}](#{upload.short_url})"
+                    raw = raw.sub(match, DiscourseMarkdown.image_markdown(upload))
               elsif raw[/\[image:.*?\d+[^\]]*\]/i]
-                raw.sub!(/\[image:.*?\d+[^\]]*\]/i, attachment_markdown(upload))
+                raw.sub!(/\[image:.*?\d+[^\]]*\]/i, DiscourseMarkdown.upload_markdown(upload))
               else
-                raw << "\n\n#{attachment_markdown(upload)}\n\n"
+                raw << "\n\n#{DiscourseMarkdown.upload_markdown(upload)}\n\n"
             else
           else
             rejected_attachments << upload
@@ -1082,14 +1078,6 @@ module Email
       Email::Sender.new(client_message, :email_reject_attachment).send
-    def attachment_markdown(upload)
-      if FileHelper.is_supported_image?(upload.original_filename)
-      else
-        "[#{upload.original_filename}|attachment](#{upload.short_url}) (#{number_to_human_size(upload.filesize)})"
-      end
-    end
     def create_post(options = {})
       options[:via_email] = true
       options[:raw_email] = @raw_email
diff --git a/script/import_scripts/base.rb b/script/import_scripts/base.rb
index 944f26c..b149ac7 100644
--- a/script/import_scripts/base.rb
+++ b/script/import_scripts/base.rb
@@ -21,8 +21,6 @@ module ImportScripts; end
 class ImportScripts::Base
   def initialize
     preload_i18n
diff --git a/script/import_scripts/base/uploader.rb b/script/import_scripts/base/uploader.rb
index 0d8acac..fc5df45 100644
--- a/script/import_scripts/base/uploader.rb
+++ b/script/import_scripts/base/uploader.rb
@@ -1,12 +1,10 @@
 require_dependency 'url_helper'
-require_dependency 'file_helper'
   class Uploader
     # Creates an upload.
     # Expects path to be the full path and filename of the source file.
     # @return [Upload]
@@ -42,22 +40,15 @@ module ImportScripts
     def html_for_upload(upload, display_filename)
-      if FileHelper.is_supported_image?(upload.url)
-        embedded_image_html(upload)
-      else
-        attachment_html(upload, display_filename)
-      end
+      DiscourseMarkdown.upload_markdown(upload, display_name: display_filename)
     def embedded_image_html(upload)
-      image_width = [upload.width, SiteSetting.max_image_width].compact.min
-      image_height = [upload.height, SiteSetting.max_image_height].compact.min
-      upload_name = upload.short_url || upload.url
-      %Q~![#{upload.original_filename}|#{image_width}x#{image_height}](#{upload_name})~
+      DiscourseMarkdown.image_markdown(upload)
     def attachment_html(upload, display_filename)
-      "[#{display_filename}|attachment](#{upload.short}) (#{number_to_human_size(upload.filesize)})"
+      DiscourseMarkdown.attachment_markdown(upload, display_name: display_filename)
     private
GitHub sha: a61ff167
One tip here, if you are passing the same upload object and keyword args display_name from method to method, that’s a clue that it might work better as an instance variables.
Also maybe the idea in the future is to use it for other kinds of objects, but if everything is an upload I would suggest making it UploadMarkdown.new(upload).to_markdown
That was the idea. I often want to put small pieces of reusable code somewhere and because of all the specific helper names I seldomly find the right place to put things. And renaming classes after a while is really hard, so I try to name helper classes as broadly as possible.
Do you still want me to refactor it to UploadMarkdown?
I think in this case it makes sense because you end up passing the upload object everywhere. If you need a more broad one in the future you could have it use the UploadMarkdown class.
DEV: Refactor helper methods for upload markdown
