DEV: Make composer-uppy-upload mixin more extensible (#14138)
This mixin needs to be shared between the composer and composer-like user interfaces. This commit makes it so the events and the underlying data model is configurable by the component extending the ComposerUploadUppy mixin.
Also removes two MessageBus unsubscribe calls which were unnecessary.
diff --git a/app/assets/javascripts/discourse/app/components/composer-editor-uppy.js b/app/assets/javascripts/discourse/app/components/composer-editor-uppy.js
index 72a67ef..152b1fb 100644
--- a/app/assets/javascripts/discourse/app/components/composer-editor-uppy.js
+++ b/app/assets/javascripts/discourse/app/components/composer-editor-uppy.js
@@ -1,6 +1,12 @@
 import ComposerEditor from "discourse/components/composer-editor";
+import { alias } from "@ember/object/computed";
 import ComposerUploadUppy from "discourse/mixins/composer-upload-uppy";
 export default ComposerEditor.extend(ComposerUploadUppy, {
   layoutName: "components/composer-editor",
+  fileUploadElementId: "file-uploader",
+  eventPrefix: "composer",
+  uploadType: "composer",
+  uppyId: "composer-editor-uppy",
+  composerModel: alias("composer"),
diff --git a/app/assets/javascripts/discourse/app/mixins/composer-upload-uppy.js b/app/assets/javascripts/discourse/app/mixins/composer-upload-uppy.js
index 815c8e4..36a82b3 100644
--- a/app/assets/javascripts/discourse/app/mixins/composer-upload-uppy.js
+++ b/app/assets/javascripts/discourse/app/mixins/composer-upload-uppy.js
@@ -33,12 +33,12 @@ import { cacheShortUploadUrl } from "pretty-text/upload-short-url";
 // functionality and event binding.
 export default Mixin.create({
-  @observes("composer.uploadCancelled")
+  @observes("composerModel.uploadCancelled")
   _cancelUpload() {
-    if (!this.get("composer.uploadCancelled")) {
+    if (!this.get("composerModel.uploadCancelled")) {
       return;
-    this.set("composer.uploadCancelled", false);
+    this.set("composerModel.uploadCancelled", false);
     this.set("userCancelled", true);
     this._uppyInstance.cancelAll();
@@ -46,8 +46,6 @@ export default Mixin.create({
   @on("willDestroyElement")
   _unbindUploadTarget() {
-    this.messageBus.unsubscribe("/uploads/composer");
     this.mobileUploadButton?.removeEventListener(
       "click",
       this.mobileUploadButtonEventListener
@@ -60,7 +58,10 @@ export default Mixin.create({
     this.element?.removeEventListener("paste", this.pasteEventListener);
-    this.appEvents.off("composer:add-files", this._addFiles.bind(this));
+    this.appEvents.off(
+      `${this.eventPrefix}:add-files`,
+      this._addFiles.bind(this)
     this._reset();
@@ -74,10 +75,13 @@ export default Mixin.create({
     this.placeholders = {};
     this._inProgressUploads = 0;
     this._preProcessorStatus = {};
-    this.fileInputEl = document.getElementById("file-uploader");
-    const isPrivateMessage = this.get("composer.privateMessage");
+    this.fileInputEl = document.getElementById(this.fileUploadElementId);
+    const isPrivateMessage = this.get("composerModel.privateMessage");
-    this.appEvents.on("composer:add-files", this._addFiles.bind(this));
+    this.appEvents.on(
     this._unbindUploadTarget();
     this._bindFileInputChangeListener();
@@ -85,12 +89,12 @@ export default Mixin.create({
     this._bindMobileUploadButton();
     this._uppyInstance = new Uppy({
-      id: "composer-uppy",
+      id: this.uppyId,
       autoProceed: true,
       // need to use upload_type because uppy overrides type with the
       // actual file type
-      meta: deepMerge({ upload_type: "composer" }, this.data || {}),
+      meta: deepMerge({ upload_type: this.uploadType }, this.data || {}),
       onBeforeFileAdded: (currentFile) => {
         const validationOpts = {
@@ -110,7 +114,7 @@ export default Mixin.create({
         if (!isUploading) {
-          this.appEvents.trigger("composer:uploads-aborted");
+          this.appEvents.trigger(`${this.eventPrefix}:uploads-aborted`);
         return isUploading;
@@ -126,7 +130,7 @@ export default Mixin.create({
               count: maxFiles,
           this._reset();
           return false;
@@ -172,8 +176,8 @@ export default Mixin.create({
         this.placeholders[file.id] = {
           uploadPlaceholder: placeholder,
-        this.appEvents.trigger("composer:insert-text", placeholder);
-        this.appEvents.trigger("composer:upload-started", file.name);
+        this.appEvents.trigger(`${this.eventPrefix}:insert-text`, placeholder);
+        this.appEvents.trigger(`${this.eventPrefix}:upload-started`, file.name);
@@ -187,19 +191,23 @@ export default Mixin.create({
       cacheShortUploadUrl(upload.short_url, upload);
-        "composer:replace-text",
+        `${this.eventPrefix}:replace-text`,
         this.placeholders[file.id].uploadPlaceholder.trim(),
         markdown
       this._resetUpload(file, { removePlaceholder: false });
-      this.appEvents.trigger("composer:upload-success", file.name, upload);
+        `${this.eventPrefix}:upload-success`,
+        file.name,
+        upload
     this._uppyInstance.on("upload-error", this._handleUploadError.bind(this));
     this._uppyInstance.on("complete", () => {
-      this.appEvents.trigger("composer:all-uploads-complete");
+      this.appEvents.trigger(`${this.eventPrefix}:all-uploads-complete`);
       this._reset();
@@ -209,7 +217,7 @@ export default Mixin.create({
       if (this.userCancelled) {
         Object.values(this.placeholders).forEach((data) => {
             data.uploadPlaceholder,
@@ -218,7 +226,7 @@ export default Mixin.create({
         this.set("userCancelled", false);
         this._reset();
-        this.appEvents.trigger("composer:uploads-cancelled");
+        this.appEvents.trigger(`${this.eventPrefix}:uploads-cancelled`);
@@ -247,7 +255,7 @@ export default Mixin.create({
     if (!this.userCancelled) {
       displayErrorForUpload(response || error, this.siteSettings, file.name);
-      this.appEvents.trigger("composer:upload-error", file);
+      this.appEvents.trigger(`${this.eventPrefix}:upload-error`, file);
     if (this._inProgressUploads === 0) {
@@ -279,7 +287,7 @@ export default Mixin.create({
       )}]()\n`;
         placeholderData.uploadPlaceholder,
         placeholderData.processingPlaceholder
@@ -288,7 +296,7 @@ export default Mixin.create({
     this._uppyInstance.on("preprocess-complete", (pluginClass, file) => {
       let placeholderData = this.placeholders[file.id];
         placeholderData.processingPlaceholder,
@@ -307,7 +315,9 @@ export default Mixin.create({
             isProcessingUpload: false,
             isCancellable: true,
-          this.appEvents.trigger("composer:uploads-preprocessing-complete");
+            `${this.eventPrefix}:uploads-preprocessing-complete`
@@ -324,7 +334,9 @@ export default Mixin.create({
       filename: escapedFilename + "(?:\\()?([0-9])?(?:\\))?",
     const globalRegex = new RegExp(regexString, "g");
-    const matchingPlaceholder = this.get("composer.reply").match(globalRegex);
+    const matchingPlaceholder = this.get("composerModel.reply").match(
+      globalRegex
     if (matchingPlaceholder) {
       // get last matching placeholder and its consecutive nr in regex
GitHub sha: cfeb6347c3c8d7083a505d9a352544d7d2d5ee3f
This commit appears in #14138 which was approved by lis2. It was merged by martin.
