DEV: make it possible to enable cdn in development environment.
diff --git a/app/helpers/application_helper.rb b/app/helpers/application_helper.rb
index 33eeba7..bd160ba 100644
--- a/app/helpers/application_helper.rb
+++ b/app/helpers/application_helper.rb
@@ -77,7 +77,7 @@ module ApplicationHelper
         path = path.gsub(/\.([^.]+)$/, '.gz.\1')
-    elsif GlobalSetting.cdn_url&.start_with?("https") && is_brotli_req?
+    elsif GlobalSetting.cdn_url&.start_with?("https") && is_brotli_req? && Rails.env != "development"
       path = path.gsub("#{GlobalSetting.cdn_url}/assets/", "#{GlobalSetting.cdn_url}/brotli_asset/")
diff --git a/config/environments/development.rb b/config/environments/development.rb
index 8308623..55a3f3b 100644
--- a/config/environments/development.rb
+++ b/config/environments/development.rb
@@ -15,6 +15,8 @@ Discourse::Application.configure do
   config.consider_all_requests_local       = true
   config.action_controller.perform_caching = false
+  config.action_controller.asset_host = GlobalSetting.cdn_url
   # Print deprecation notices to the Rails logger
   config.active_support.deprecation = :log
GitHub sha: 1504fe72
