DEV: make Jobs.enqueue tests less fragile
Previously we depended on non Sidekiq specific mocking which is not the official way of testing Sidekiq, this made these tests very fragile
New testing is more robust and complete
diff --git a/spec/jobs/jobs_spec.rb b/spec/jobs/jobs_spec.rb
index 01cbe6a..a058971 100644
--- a/spec/jobs/jobs_spec.rb
+++ b/spec/jobs/jobs_spec.rb
@@ -11,13 +11,40 @@ describe Jobs do
       it 'enqueues a job in sidekiq' do
-        Sidekiq::Client.expects(:enqueue).with(Jobs::ProcessPost, post_id: 1, current_site_id: 'default')
-        Jobs.enqueue(:process_post, post_id: 1)
+        Sidekiq::Testing.fake! do
+          jobs = Jobs::ProcessPost.jobs
+          jobs.clear
+          Jobs.enqueue(:process_post, post_id: 1)
+          expect(jobs.length).to eq(1)
+          job = jobs.first
+          expected = {
+            "class" => "Jobs::ProcessPost",
+            "args" => [{ "post_id" => 1, "current_site_id" => "default" }],
+            "queue" => "default"
+          expect(job.slice("class", "args", "queue")).to eq(expected)
+        end
       it "does not pass current_site_id when 'all_sites' is present" do
-        Sidekiq::Client.expects(:enqueue).with(Jobs::ProcessPost, post_id: 1)
-        Jobs.enqueue(:process_post, post_id: 1, all_sites: true)
+          jobs.clear
+          Jobs.enqueue(:process_post, post_id: 1, all_sites: true)
+          job = jobs.first
+          expected = {
+            "args" => [{ "post_id" => 1 }],
+        end
       it "doesn't execute the job" do
@@ -27,10 +54,23 @@ describe Jobs do
       it "should enqueue with the correct database id when the current_site_id option is given" do
-        Sidekiq::Client.expects(:enqueue).with do |arg1, arg2|
-          arg2[:current_site_id] == 'test_db' && arg2[:sync_exec].nil?
+          jobs.clear
+          Jobs.enqueue(:process_post, post_id: 1, current_site_id: 'test_db')
+          job = jobs.first
+          expected = {
+            "args" => [{ "post_id" => 1, "current_site_id" => "test_db" }],
-        Jobs.enqueue(:process_post, post_id: 1, current_site_id: 'test_db')
GitHub sha: 824c3420
