DEV: manually ignore files as .eslintignore is not working
diff --git a/.eslintignore b/.eslintignore
deleted file mode 100644
index ae1bf2f..0000000
--- a/.eslintignore
+++ /dev/null
@@ -1 +0,0 @@
-/manager-client/**/*.js
diff --git a/assets/docker-manager-app.js b/assets/docker-manager-app.js
index 6471475..37a3a8b 100644
--- a/assets/docker-manager-app.js
+++ b/assets/docker-manager-app.js
@@ -1,3 +1,5 @@
+/*eslint-disable*/
 "use strict"
 define("manager-client/app",["exports","manager-client/resolver","ember-load-initializers","manager-client/config/environment"],function(e,t,n,r){var a
 Object.defineProperty(e,"__esModule",{value:!0}),e.default=void 0,Ember.MODEL_FACTORY_INJECTIONS=!0,a=Ember.Application.extend({modulePrefix:r.default.modulePrefix,podModulePrefix:r.default.podModulePrefix,Resolver:t.default}),(0,n.default)(a,r.default.modulePrefix)
@@ -129,3 +131,5 @@ var t=Ember.HTMLBars.template({id:"H4zT5h6q",block:'{"symbols":[],"statements":[
 e.default=t})
 define("manager-client/config/environment",[],function(){try{var e="manager-client/config/environment",t=document.querySelector('meta[name="'+e+'"]').getAttribute("content"),n={default:JSON.parse(decodeURIComponent(t))}
 return Object.defineProperty(n,"__esModule",{value:!0}),n}catch(r){throw new Error('Could not read config from meta tag with name "'+e+'".')}}),runningTests||require("manager-client/app").default.create({name:"manager-client",version:"0.0.0+b1a85b04"})
+/*eslint-enable*/
diff --git a/assets/docker-manager-vendor.js b/assets/docker-manager-vendor.js
index 5f28777..3d4d51f 100644
--- a/assets/docker-manager-vendor.js
+++ b/assets/docker-manager-vendor.js
@@ -1,3 +1,5 @@
+/*eslint-disable*/
 window.EmberENV={FEATURES:{},EXTEND_PROTOTYPES:{Date:!1}}
 var loader,define,requireModule,require,requirejs,runningTests=!1;(function(e){"use strict"
 function t(){var e=Object.create(null)
@@ -6249,3 +6251,5 @@ return e._dict=null,delete e._dict,e}}),define("moment/index",["exports","moment
 function n(e,n){if(t.default.isMoment(e)&&t.default.isMoment(n))return e.isBefore(n)?-1:e.isSame(n)?0:1
 throw new Error("Arguments provided to `compare` are not moment objects")}Object.defineProperty(e,"__esModule",{value:!0}),t.default.prototype.compare=n,t.default.compare=n,t.default.prototype.clone=function(){return(0,t.default)(this)},e.default=t.default}),define("moment/lib",["exports"],function(e){"use strict"
 Object.defineProperty(e,"__esModule",{value:!0}),e.default=self.moment})
+/*eslint-enable*/
diff --git a/manager-client/app/components/x-console.js b/manager-client/app/components/x-console.js
index d474ff1..433f86f 100644
--- a/manager-client/app/components/x-console.js
+++ b/manager-client/app/components/x-console.js
@@ -1,3 +1,5 @@
+/* eslint-disable */
 import Component from "@ember/component";
 import { observer } from "@ember/object";
 import { scheduleOnce } from "@ember/runloop";
@@ -5,7 +7,7 @@ import { scheduleOnce } from "@ember/runloop";
 export default Component.extend({
   classNameBindings: [":logs"],
-  _outputChanged: observer("output", function() {
+  _outputChanged: observer("output", function () {
     scheduleOnce("afterRender", this, "_scrollBottom");
@@ -18,5 +20,7 @@ export default Component.extend({
   didInsertElement() {
     this._super(...arguments);
     this._scrollBottom();
+/* eslint-enable */
diff --git a/manager-client/app/controllers/upgrade.js b/manager-client/app/controllers/upgrade.js
index 3856d0a..e87e962 100644
--- a/manager-client/app/controllers/upgrade.js
+++ b/manager-client/app/controllers/upgrade.js
@@ -1,3 +1,5 @@
 /* global MessageBus, bootbox */
 import Repo from "manager-client/models/repo";
 import Controller from "@ember/controller";
@@ -15,20 +17,20 @@ export default Controller.extend({
   complete: equal("status", "complete"),
   failed: equal("status", "failed"),
-  multiUpgrade: computed("model.length", function() {
+  multiUpgrade: computed("model.length", function () {
     return this.get("model.length") !== 1;
-  title: computed("model.@each.name", function() {
+  title: computed("model.@each.name", function () {
     return this.get("multiUpgrade") ? "All" : this.get("model")[0].get("name");
-  isUpToDate: computed("model.@each.upToDate", function() {
-    return this.get("model").every(repo => repo.get("upToDate"));
+  isUpToDate: computed("model.@each.upToDate", function () {
+    return this.get("model").every((repo) => repo.get("upToDate"));
-  upgrading: computed("model.@each.upgrading", function() {
-    return this.get("model").some(repo => repo.get("upgrading"));
+  upgrading: computed("model.@each.upgrading", function () {
+    return this.get("model").some((repo) => repo.get("upgrading"));
   repos() {
@@ -37,7 +39,7 @@ export default Controller.extend({
   updateAttribute(key, value, valueIsKey = false) {
-    this.get("model").forEach(repo => {
+    this.get("model").forEach((repo) => {
       value = valueIsKey ? repo.get(value) : value;
       repo.set(key, value);
@@ -56,8 +58,8 @@ export default Controller.extend({
         if (msg.value === "complete") {
           this.get("model")
-            .filter(repo => repo.get("upgrading"))
-            .forEach(repo => {
+            .filter((repo) => repo.get("upgrading"))
+            .forEach((repo) => {
               repo.set("version", repo.get("latest.version"));
@@ -70,7 +72,7 @@ export default Controller.extend({
-  upgradeButtonText: computed("upgrading", function() {
+  upgradeButtonText: computed("upgrading", function () {
     if (this.get("upgrading")) {
       return "Upgrading...";
     } else {
@@ -79,7 +81,7 @@ export default Controller.extend({
   startBus() {
-    MessageBus.subscribe("/docker/upgrade", msg => {
+    MessageBus.subscribe("/docker/upgrade", (msg) => {
       this.messageReceived(msg);
@@ -98,8 +100,8 @@ export default Controller.extend({
       if (this.get("multiUpgrade")) {
         this.get("model")
-          .filter(repo => !repo.get("upToDate"))
-          .forEach(repo => repo.set("upgrading", true));
+          .filter((repo) => !repo.get("upToDate"))
+          .forEach((repo) => repo.set("upgrading", true));
         return Repo.upgradeAll();
@@ -114,11 +116,11 @@ export default Controller.extend({
       bootbox.confirm(
         "WARNING: You should only reset upgrades that have failed and are not running.\n\n" +
           "This will NOT cancel currently running builds and should only be used as a last resort.",
-        result => {
+        (result) => {
           if (result) {
               return Repo.resetAll(
-                this.get("model").filter(repo => !repo.get("upToDate"))
+                this.get("model").filter((repo) => !repo.get("upToDate"))
               ).finally(() => {
                 this.reset();
                 this.updateAttribute("upgrading", false);
@@ -132,6 +134,8 @@ export default Controller.extend({
diff --git a/manager-client/app/discourse.js b/manager-client/app/discourse.js
index 9ce1311..0a8b583 100644
--- a/manager-client/app/discourse.js
+++ b/manager-client/app/discourse.js
@@ -1,3 +1,5 @@
 function init() {
   const data = Em.$("#preloaded-data").data("preload");
   Em.$.extend(Discourse, data);
@@ -17,7 +19,9 @@ const Discourse = {
     if (url[0] !== "/") url = "/" + url;
     return this.rootUrl + url;
 export default Discourse;
diff --git a/manager-client/app/routes/upgrade.js b/manager-client/app/routes/upgrade.js
index efae099..40a4008 100644
--- a/manager-client/app/routes/upgrade.js
+++ b/manager-client/app/routes/upgrade.js
@@ -13,9 +13,9 @@ export default Route.extend({
   afterModel(model) {
GitHub sha: ef101df3
