DEV: migrate test to async/await
diff --git a/test/javascripts/acceptance/spoiler-button-test.js.es6 b/test/javascripts/acceptance/spoiler-button-test.js.es6
index ce46de5..63a8602 100644
--- a/test/javascripts/acceptance/spoiler-button-test.js.es6
+++ b/test/javascripts/acceptance/spoiler-button-test.js.es6
@@ -1,7 +1,7 @@
 import { acceptance } from "helpers/qunit-helpers";
 import { clearPopupMenuOptionsCallback } from "discourse/controllers/composer";
-acceptance('Spoiler Button', {
+acceptance("Spoiler Button", {
   loggedIn: true,
   settings: { spoiler_enabled: true },
   beforeEach() {
@@ -9,97 +9,107 @@ acceptance('Spoiler Button', {
-function findTextarea() {
-  return find(".d-editor-input")[0];
-test('spoiler button', assert => {
-  const popUpMenu = selectKit('.toolbar-popup-menu-options');
-  visit("/");
-  andThen(() => {
-    assert.ok(exists('#create-topic'), 'the create button is visible');
-  click('#create-topic');
-  popUpMenu.expand().selectRowByValue('insertSpoiler');
-  andThen(() => {
-    assert.equal(
-      find(".d-editor-input").val(),
-      `[spoiler]${I18n.t("composer.spoiler_text")}[/spoiler]`,
-      'it should contain the right output'
-    const textarea = findTextarea();
-    assert.equal(textarea.selectionStart, 9, 'it should start highlighting at the right position');
-    assert.equal(textarea.selectionEnd, I18n.t("composer.spoiler_text").length + 9, 'it should end highlighting at the right position');
-  fillIn('.d-editor-input', "This is hidden");
-  andThen(() => {
-    textarea.selectionStart = 0;
-    textarea.selectionEnd = textarea.value.length;
-  andThen(() => {
-    assert.equal(
-      `[spoiler]This is hidden[/spoiler]`,
-    assert.equal(textarea.selectionEnd, 23, 'it should end highlighting at the right position');
-  fillIn('.d-editor-input', "Before this is hidden After");
-  andThen(() => {
-    textarea.selectionStart = 7;
-    textarea.selectionEnd = 21;
-  andThen(() => {
-    assert.equal(
-      `Before [spoiler]this is hidden[/spoiler] After`,
-    assert.equal(textarea.selectionStart, 16, 'it should start highlighting at the right position');
-    assert.equal(textarea.selectionEnd, 30, 'it should end highlighting at the right position');
-  fillIn('.d-editor-input', "Before\nthis is hidden\nAfter");
-  andThen(() => {
-  andThen(() => {
-    assert.equal(
-      `Before\n[spoiler]this is hidden[/spoiler]\nAfter`,
+test("spoiler button", async assert => {
+  const popUpMenu = selectKit(".toolbar-popup-menu-options");
+  await visit("/");
+  assert.ok(exists("#create-topic"), "the create button is visible");
+  await click("#create-topic");
+  await popUpMenu.expand();
+  await popUpMenu.selectRowByValue("insertSpoiler");
+  assert.equal(
+    find(".d-editor-input").val(),
+    `[spoiler]${I18n.t("composer.spoiler_text")}[/spoiler]`,
+    "it should contain the right output"
+  let textarea = await find(".d-editor-input")[0];
+  assert.equal(
+    textarea.selectionStart,
+    9,
+    "it should start highlighting at the right position"
+  assert.equal(
+    textarea.selectionEnd,
+    I18n.t("composer.spoiler_text").length + 9,
+    "it should end highlighting at the right position"
+  await fillIn(".d-editor-input", "This is hidden");
+  textarea.selectionStart = 0;
+  textarea.selectionEnd = textarea.value.length;
+  assert.equal(
+    `[spoiler]This is hidden[/spoiler]`,
+  assert.equal(
+    9,
+  assert.equal(
+    23,
+  await fillIn(".d-editor-input", "Before this is hidden After");
+  textarea.selectionStart = 7;
+  textarea.selectionEnd = 21;
+  assert.equal(
+    `Before [spoiler]this is hidden[/spoiler] After`,
+  assert.equal(
+    16,
+  assert.equal(
+    30,
+  await fillIn(".d-editor-input", "Before\nthis is hidden\nAfter");
+  assert.equal(
+    `Before\n[spoiler]this is hidden[/spoiler]\nAfter`,
+  assert.equal(
+    16,
+  assert.equal(
+    30,
GitHub
sha: 4b73e274
