DEV: Minor test clarification
Replace (0...3) for with 3.times.
diff --git a/spec/components/distributed_mutex_spec.rb b/spec/components/distributed_mutex_spec.rb
index ddce89a..e04727a 100644
--- a/spec/components/distributed_mutex_spec.rb
+++ b/spec/components/distributed_mutex_spec.rb
@@ -100,7 +100,7 @@ describe DistributedMutex do
   context "executions" do
     it "should not allow critical sections to overlap" do
-      connections = (0...3).map { DiscourseRedis.new }
+      connections = 3.times.map { DiscourseRedis.new }
       scenario =
         Concurrency::Scenario.new do |execution|
GitHub sha: 9bb15efc
