DEV: More improvements to `InlineUploads`.
DEV: More improvements to InlineUploads.
  • Convert inline links to short path
<link> <link>
<link>
to
<short_path> <short_path>
<short_path>
diff --git a/app/services/inline_uploads.rb b/app/services/inline_uploads.rb
index 4605a3f..70cbbf9 100644
--- a/app/services/inline_uploads.rb
+++ b/app/services/inline_uploads.rb
@@ -56,18 +56,58 @@ class InlineUploads
     db = RailsMultisite::ConnectionManagement.current_db
     regexps = [
-      /(^|\s)?(https?:\/\/[a-zA-Z0-9\.\/-]+\/uploads\/#{db}#{UPLOAD_REGEXP_PATTERN})($|\s)/,
+      /(https?:\/\/[a-zA-Z0-9\.\/-]+\/uploads\/#{db}#{UPLOAD_REGEXP_PATTERN})/,
     if Discourse.store.external?
-      regexps << /(^|\s)?(https?:#{SiteSetting.Upload.s3_base_url}#{UPLOAD_REGEXP_PATTERN})($|\s)?/
-      regexps << /(^|\s)?(#{SiteSetting.Upload.s3_cdn_url}#{UPLOAD_REGEXP_PATTERN})($|\s)?/
+      regexps << /(https?:#{SiteSetting.Upload.s3_base_url}#{UPLOAD_REGEXP_PATTERN})/
+      regexps << /(#{SiteSetting.Upload.s3_cdn_url}#{UPLOAD_REGEXP_PATTERN})/
     regexps.each do |regexp|
-      markdown.scan(regexp) do |match|
-        if matched_uploads(match[1]).present?
-          raw_matches << [match[1], match[1], +"![](#{PLACEHOLDER})", $~.offset(0)[0]]
+      indexes = Set.new
+      markdown.scan(/(\n{2,}|\A)#{regexp}$/) do |match|
+        if match[1].present?
+          index = $~.offset(2)[0]
+          indexes << index
+          raw_matches << [match[1], match[1], +"![](#{PLACEHOLDER})", index]
+        end
+      end
+      markdown.scan(/^#{regexp}(\s)/) do |match|
+        if match[0].present?
+          index = $~.offset(0)[0]
+          next if indexes.include?(index)
+          indexes << index
+          raw_matches << [
+            match[0],
+            match[0],
+            +"#{Discourse.base_url}#{PATH_PLACEHOLDER}",
+            $~.offset(0)[0]
+        end
+      end
+      markdown.scan(/\[[^\[\]]*\]: #{regexp}/) do |match|
+          index = $~.offset(1)[0]
+          indexes << index
+        end
+      end
+      markdown.scan(/((\n|\s)+)#{regexp}/) do |match|
+        if matched_uploads(match[2]).present?
+          next if indexes.include?($~.offset(3)[0])
+          raw_matches << [
+            match[2],
+            match[2],
+            $~.offset(0)[0]
@@ -125,7 +165,7 @@ class InlineUploads
   def self.match_md_reference(markdown)
     markdown.scan(/(\[([^\]]+)\]:([ ]+)(\S+))/) do |match|
-      if match[3] && matched_uploads(match[3]) && block_given?
+      if match[3] && matched_uploads(match[3]).present? && block_given?
         yield(
           match[0],
           match[3],
diff --git a/spec/services/inline_uploads_spec.rb b/spec/services/inline_uploads_spec.rb
index 4bbbc7d..0ec00d0 100644
--- a/spec/services/inline_uploads_spec.rb
+++ b/spec/services/inline_uploads_spec.rb
@@ -124,25 +124,37 @@ RSpec.describe InlineUploads do
       it "should correct markdown references" do
         md = <<~MD
-        This is a [some reference] somethign
+        This is a [some reference] something
         [some reference]: #{Discourse.base_url}#{upload.url}
+        <img src="#{upload.url}">
         MD
         expect(InlineUploads.process(md)).to eq(<<~MD)
         [some reference]: #{Discourse.base_url}#{upload.short_path}
+        ![](#{upload.short_url})
         MD
-      it "should correct raw image URLs to the short version" do
+      it "should correct raw image URLs to the short url and paths" do
         md = <<~MD
-        #{Discourse.base_url}#{upload3.url} #{Discourse.base_url}#{upload3.url}
+        #{Discourse.base_url}#{upload.url}
+        #{Discourse.base_url}#{upload.url} #{Discourse.base_url}#{upload2.url}
+        #{Discourse.base_url}#{upload3.url}
         MD
-        ![](#{upload3.short_url}) ![](#{upload3.short_url})
+        #{Discourse.base_url}#{upload.short_path} #{Discourse.base_url}#{upload2.short_path}
+        ![](#{upload3.short_url})
         MD
@@ -174,7 +186,7 @@ RSpec.describe InlineUploads do
         ![some image](#{upload.short_url} "some title")
         ![some image](#{upload2.short_url})![some image](#{upload3.short_url})
+        #{Discourse.base_url}#{upload3.short_path} #{Discourse.base_url}#{upload3.short_path}
         ![|5x4](#{upload.short_url})
         MD
@@ -469,8 +481,8 @@ RSpec.describe InlineUploads do
           MD
-          ![](#{upload2.short_url}) ![](#{upload2.short_url})
+          #{Discourse.base_url}#{upload2.short_path} #{Discourse.base_url}#{upload2.short_path}
           ![some image](#{upload.short_url})
GitHub sha: ee142c21
Do you hoist out all code blocks upfront then? Eg: replace
something something something
With
GUID
And then replace back once done?
